With the amount of products being released growing and the requests for more Wyze Rule Actions, we have consolidated them here.
This list is for Wyze Rule Actions (things that can be caused by a Wyze Rule Schedule, Shortcut or Device Trigger). For more Wyze Rule Device Triggers, see this related topic: Add More Device Triggers for Wyze Rules.
Please click VOTE at the top to indicate your desire for more Wyze Rule Actions. You can reply to this topic with thoughts on which of these are most important to you, We understand that having these requests consolidated in a single #wishlist topic means that you canāt vote on them individually. That is why commenting about your favorites, use cases, and personal significance is important. Wyze will consider those comments in prioritizing implementation.
Existing Rule Actions:
Turn on/off device (Privacy Mode for Cam Pan v3)
Upload a short video to the cloud
Restart the camera
Turn on/off motion detection
Turn on/off notifications (per camera/sensor and globally)
Reset position (Pan Cam and Pan Cam v2 only)
Set brightness/color temperature (Bulbs & Light Strips)
Set color selection (Bulb Color & Light Strips)
Initiate color blink with user-selected color (Bulb Color & Light Strips)
Initiate color blink for lighting product groups
Initiate color temperature blink with user-selected temperature (Bulb v1, Bulb White (Bulb v2))
Initiate color temperature blink for lighting product groups
Turn on/off integrated spotlight & user-defined on-period up to 60 minutes (Cam v3 Pro only)
Turn on/off Spotlight (Cam v3 only)
Turn on/off Lamp Socket (Cam v3 only)
Turn on/off Floodlight (Cam v3 only)
Air Purifier - turn on to Auto/Sleep modes
Garage Door Controller - Close
Plug - turn on, off & user-defined period up to 60 minutes
Plug Outdoor - turn on, off & user-defined period up to 60 minutes
Robot Vacuum - start to clean
Robot Vacuum - stop cleaning and return to charging station
Switch - turn on, off & user-defined period up to 60 minutes
Thermostat - turn on Heat/Cool mode
Thermostat - turn on/off mode
Thermostat - set to Home/Away/Sleep
Thermostat - turn notifications on/off
Requested Rule Actions:
Turn on/off sound detection
Change motion/sound detection sensitivity 0-100
Delete all alert clips for camera
Turn Pan Scan on/off
Turn Motion Tracking on/off
Night vision on/off/auto
Infrared (IR) emitters on/off
Detection zone on/off
Save a still image
Sync camera time (any or all)
Change SD card record mode: Off, Event Only, Continuous
An āAll cameraā group under Device Actions (instead of having to add each cameraās action individually) [NOTE: actions can now be performed on user-defined groups]
Pan Cam: move to a specific camera memorized position or waypoint
Add an āall devicesā option for any action
Tell Alexa or Google device to show camera
Toggle notifications for Wyze Sense sensors by event type (eg. opened vs left open)
Toggle Smart Video Alert recording for Wyze Sense sensors (by sensor or event type)
Add and remove devices from groups
Vacation Mode on/off (Bulbs, Light Strips and Plugs, single and group)
Activate a lighting Scene (Bulbs & Light Strips)
Change brightness/color temp/color/on/off for X minutes then return to previous state (Bulbs & Light Strips)
Flash/blink on/off for a user defined period (Bulbs & Light Strips)
Flash/blink āxā number of times (Bulbs & Light Strips)
Disable/Enable AI Detection type (Person, Vehicle, Pet, Package, etc.)
Disable/Enable AI Notification type (Person, Vehicle, Pet, Package, etc.)
Pause (wait) X seconds/minutes
Record an event to the SD card (even if no motion is detected)
Enable/disable other rules (event triggered and scheduled)
External HTML call
Toggle on/off state (all Wyze IOT devices)
Execute an existing Shortcut (button)
Change camera resolution HD/SD/360p (any or all cameras)
Unlock Wyze Lock
Display camera feed in app on tablet device
Trigger start of a pre-defined time lapse video capture
Activate/Deactivate a schedule
Change detection sensitivity
Turn notifications off for X minutes
Activate Doorbell Chime
Share cam according to a rule schedule
Turn on/off device status light
HMS system mode change (Disarmed, Home, Away, Test)
HMS system Alarm Response (Critical Alert, Push notification, Off)
Robot Vacuum clean specific room
Sprinkler zone on/off and for X time
Floodlight brightness control
Change Floodlight Control (Auto/On/Off)
Air Purifier - turn On (currently only allows Off/Auto)
Air Purifier - turn On/Off LED display on physical device
Air Purifier - Set fan speed
Start a Scheduled Recording (WCO & WCO v2)
Send custom message as a push notification.
Garage Door Controller - Open
Turn on for # (BR30 Bulb)
Turn Sun Match On. (BR30 Bulb)
Turn Sun Match Off. (BR30 Bulb)
Turn on for X seconds < current 1 minute minimum restriction (Wyze Switch, all plug types, all lighting product types including Floodlight, Lamp Socket, Spotlight and v3 Pro Spotlight)
Thermostat: add/remove Wyze Room Sensors to/from Auto Comfort
If more (reasonable) suggestions are made in the comments, they will be added to the above list.
Has there been a solution found to separate scheduled alerts between Sound and Motion? I also would like to add the feature where Sound and Motion have separate schedules.
The Shortcuts feature allows setting variable schedules for a variety of actions. However, turning sound detection on and off are not currently available as possible actions. If these are added to actions, then it will be possible to schedule this using shortcuts.
Please VOTE for it using the button at the top of this page.
Need to be able to turn On/Off/Auto the night vision mode.
The night vision threshold is too finicky for when my outdoor sensor light goes on and the cam keeps flipping back and forth between day and night mode, like a blinking kid staring at the sun. Also the pan cam tracks the mode changes as motion and keeps spazzing out moving back and forth randomly, generating random alerts.
⦠A night vision sensitivity slider might also help with this
Another action that would be great, setting different motion detection areas.
I have a busy street during the day and donāt need to get alerts for every car that drives by. But at night there can be suspicious activity of people loitering, where id like to expand the detection area. It would be great if i can shift the detection areas on a schedule for night and day
I worry about the longevity of the pan motor due to constant panning when I am away. Being able to turn pan on upon motion or sound detection (or both) would save wear and tear on the motor. Actually, this would apply not only to shortcuts, but use in general. I thought of it when setting up an āAwayā shortcut (I will use it as a security device - Camera will off when home).
This, for me, is the number one improvement Iād like to see right now. It would cut down dramatically the amount of time and hassle I spend activating and deactivating certain features on my cams every time I leave or return home. Mostly itās being able to turn on\off the pan scan, motion tracking and sound detection features. Being able to set them to activate on my automated schedule while Iām at work at night would help me keep an eye on my elderly mother. I have to disable the sound alerts until after sheās in bed or else I get tons of false alerts. Iām often either too busy at work or just forget to manually go into app to reactivate sound alerts so I can be alerted to smoke\CO alarms going off. I know that there are separate alarm settings for smoke\CO alarms, but I have tested this multiple times by manually activating my smoke alarms and I get no notifications from my V2 cam.
Update all thumbnails. I know there is a roadmap for that, but it seems that might be more of an action.
Just visualizing a path Wyze could follow IF they had loadable profiles of settings, anything that simply changes the state of the setting would be updated via loading the users preferred profiles and anything requiring an action would be, well an action. Three of the existing actions (Turn on/off camera, Turn on/off camera and Turn on/off notifications (per camera and globally)), are changing settings. Two (Upload a short video to the cloud and Restart the camera) are what I would consider actions.
The addition āactionsā in this roadmap can easily be recognized as profile settings vs. actions.
Turn on/off sound detection (**profile**)
Change motion/sound detection sensitivity 0-100 (**profile**)
Delete all alert clips for camera (**action**)
Turn Pan Scan on/off (**profile**)
Turn Motion Tracking on/off (**profile**)
Night vision on/off/auto (**profile**)
Detection zone on/off (**profile**)
Save a still image (**action**)
Sync camera time (any or all) (**action**)
It would be great if an active short-cut would be highlighted in the app. Currently, touching a short-cut to activate it causes it to blink a few times, but then it looks just like any other short-cut.
I think having certain actions based on location of the user would be really helpful⦠similar with Reminder⦠location. So user is out of the house (area), turn on/off certain actions/notifications.
Why hasnāt Sound Detection On/Off added to scheduled events? Like what you can do with motion?
I would like the sound to detect when Iām gone and not when Iām at home. I have to physically go into turn off sound detection but I can schedule motion? Weird.
