Rules erratic
…for the last few days.
Person detection on v2 (legacy) registers person, uploads 12-sec clip and sends notification, but the related Rule (if person detected on v2, turn on bulb, turn on plug) only fires erratically - sometimes yes sometimes no.
The rule is time restricted, like 11:01p - 5:55a. I’m on the new rules engine. These rules have been pretty stable for nearly a year.
If this should be merged into a bigger existing topic please do. I looked but found only this:
Also, the category of this post might better be Services and Integrations? And I didn’t find ‘Rules’ tag under either Cam or Services categories, fwiw.
/edited
/edit - documented some specifics in post 5 below
/edit - documented some specifics in post 6 below
/edit - documented some specifics in post 7 below
/edit - documented some specifics in posts 8 & 9 below
/edit - documented some specifics in posts 11 & 12 below
/edit - Done logging. How do Rules work operationally? Post 13.
/edit - Moved Topic to ‘Beta’ category to encourage dev review (as suggested)
/edit - Some light regarding AWS+Wyze operationally. Post 15.
There is another thread here creates after the one I made about the same issue
https://forums.wyze.com/t/what-happened-to-the-rules/193827
Thanks tina! :slight_smile:
Do rules have any dependency on Amazon Web Services (AWS)? Or do they operate exclusively on Wyze servers?
I know there was an AWS outage within the last week that Wyze noted.
The thing is, if the New Rules Engine implementation may be causing unpredictable behavior across the rules function, I’ll just chill and accept that it’s in transition - as opposed to fiddling/changing things in an attempt to fix, which I always fear may make things worse.
Is that an announcement Wyze could make?: There may be irregular Rules behavior for the next week or so. Chill (don’t troubleshoot.) We’ll notify you when we’re done.
Ok, last night (Sun/Mon), Cam 1, Event Recording in effect from 11p-6a, Notification on Person Detection, Rule Trigger on Person Detection in effect from 11:01p-5:55a.
11:28p
Event-Person-Notify-
Revise Rule by changing start time by 1 min: 11:02p
11:46p
Event-Person-Notify-Trigger
11:57p
2:11a
2:36a
4:35a
ERRATIC: 3 of 6 failed. I am considering the Rule Trigger failed by the absence of an entry in the Rules History. The Rule Effect (Plug turns on lights) is not in my living space so I’ve haven’t documented the failure by observation.
Last night (Mon/Tue), Cam 1, Event Recording in effect from 11p-6a, Notification on Person Detection, Rule Trigger on Person Detection in effect from 11:02p-5:55a.
11:12p
Revise Rule by changing start time by 1 min: 11:03p
11:19p
11:58p
5:25a
ALL Rule Triggers failed - no entry in the Rules History. The Rule Effect (Plug turns on lights) failure WAS documented by observation for the first two Events.
I thought Revising/Saving the failing Rule might ‘refresh’ its operation, but last night it had no effect.
Last night (Tue/Wed), Cam 1, Event Recording in effect from 11p-6a, Notification on Person Detection, Rule Trigger on Person Detection in effect from 11:03p-5:55a.
11:05p
11:30p
12:11a
Event-Person-Notify-Trigger (Failed: Device offline)
1:09a
1:17a
2:53a
3:34a
3:55a
5:19a
5:42a
5:54a
ERRATIC: 9 of 11 failed. 6 in the prior way: absence of an entry in Rules History.
And 3 in a NEW way: entry in Rules History but status of Failed: Device offline.
Early evening (Wed/Thu), rebooted the Plug that is the Target of the Rule
Last night (Wed/Thu), Cam 1, Event Recording in effect from 11p-6a, Notification on Person Detection, Rule Trigger on Person Detection in effect from 11:03p-5:55a.
11:08p
11:27p
12:21a
1:34a
3:14a
ERRATIC : 1 of 5 failed. But BETTER
Rebooting the target Plug may have helped (it didn’t hurt :slight_smile: )
Cam 2, a different Cam, a similar but separate Rule
Event Recording in effect from 11p-6a, Notification on Person Detection, Rule Trigger on Person Detection in effect from 11:01p-5:59a, Target is two Bulbs (not in a group)
Summary
Mon/Tue:   1 of 4 Failed
Tue/Wed   1 of 6 Failed
Wed/Thu   0 of 5 Failed
ERRATIC (but improving?)
Sent logs to support and they’re currently looking into it.
Last night (Thu/Fri), Cam 1 , Event Recording in effect from 11p-6a, Notification on Person Detection, Rule Trigger on Person Detection in effect from 11:03p-5:55a.
11:07p
11:33p
11:45a
12:26a
12:45a
1:21a
2:53a
3:10a
5:36a
ERRATIC : 3 of 9 failed.
Cam 2 , a different Cam, a similar but separate Rule
Summary
Thu/Fri:   1 of 7 Failed
ERRATIC   Does this need to be perfect? Not for my purposes, but it’s interesting to know.
Ok, I’m done with the logging. It’s been mildly tedious but helpful to Wyze and the community, I suppose.
Currently I run an Android 6 device that is still powerful enough but which has been OS-excluded from present and future Wyze app versions.
I also run Android 7 emulator Bluestacks on a PC which will be able to use the latest Wyze app into the future.
Regarding firmware, all my v2 cams are (as of today) two versions removed from the latest release. I routinely monitor the success of firmware releases (add features/fixes without introducing new issues to troubleshoot) before accepting the upgrade.
I prize stability quite highly.
I don’t like to physically futz with the cams which are perfectly mounted and aimed with precise motion detection zones established. Remounting multiple cams (for me) is more than tedious, it’s painful.
Operational perfection is nice but I am tolerant of, I donno, 90% plus? I don’t use the cams/plugs/bulbs for anything crucial.
Does any of the foregoing bear upon the ERRATIC Rules performance I am demonstrating?
I don’t know enough (anything, really) about how Rules operate on the backend to say. I mean do they reside primarily in the App software, the Firmware, the backend Server, AWS? Are they not primarily anywhere, but more evenly distributed among components? Heck if I know.
Maybe it makes a difference that I’m running two versions back in both the app and firmware. Maybe it doesn’t.
Maybe the backend is where all the action is. :cloud:
Maybe someone who knows can give me a clue. Please? :slight_smile:
Upon reflection, changed this from 95% (1 fail in 20) to 90% (1 fail in 10). I wonder how demanding of perfection the average user is…
FWIW, found some light re AWS:
8/31/21 12:00 PM PT- We use a service called Amazon Web Services (AWS) for tasks such as sending notifications. Currently, this service is experiencing difficulty and this is impacting some of our products. Amazon is working on it now but you may experience difficulty with making in-app purchases, IFTTT, Alexa, or Google integrations, notification delays, trouble with Cam Plus Events not playing smoothly or experiencing errors, or a delay when using Wyze Home Monitoring alarms or disarming your system. We apologize and appreciate your patience.
Here:
Unboxed a brand new v2, updated it to the latest firmware, running the latest app on Android 7, created a new Rule to light a bulb when cam detects person.
Same results as demonstrated above.
5 of 11 failed.
POOR
So did your V2 report a person? I used to have a V2 set that way, but I later replaced it with a V3. So I don’t have anything set up that way ATM.
All that aside, I do have a motion sensor tied in to the same Bulb. So if the motion sensor sees something, or the Person Detection reports a person, the signal light lights. I’ve never had a failure to detect a person, but I don’t know how often the “person detection” is the reason for the detection. The PIR motion sensor is much faster.
So in the failures, did the light fail WITH a confirmed person detection? That would be the difference between a poor rule implementation, and a poor person detection. Gotta focus the fix…
I set up a v2 cam, trigger: on Person Detection, action: turn on a Wyze Bulb Color, turn on 2 regular Wyze bulbs, and turn on a Wyze Plug. Worked perfectly. Maybe I missed something…
@Newshound @Seapup
Hey Gents
Legacy Person Detection on v2 registers person, uploads 12-sec clip and sends person notification, but the related Rule (if person detected on v2, turn on bulb) only fires erratically. When it fails, the bulb doesn’t light and there is no entry in the Rules History.
Logged in thread above like so:
SUCCEED
FAIL
I ran the new v2 I set up (post #16) for an hour this morning:
4 of 8 failed.
Events List:
Corresponding Notifications Received
Corresponding Rules History
Corresponding Rules
To complicate this further, yesterday two rules disappeared from my Rules List without my deleting them. They were both shut-off-bulb-if-lit-for-x-minutes actions, FWIW (one of them was “Byd Off”, which I had created for testing a few days ago. Created “Byd 0” to replace it, which I used this morning.)
Also, last night, the two person detection trigger rules I actually use (the ones logged in the body of this thread) offered their worst performance yet:
9 of 10 failed.
And, all of my v2’s’ are now running the latest firmware as of yesterday.
I’ll DM you an invite to a convo between myself and a Wyze engineer (to which this thread is a companion) so’s you can have a look see how far we got (impasse, I’d say.)
Thanks boys, -peep
