It’s called WiFi Tracking and allows the new version to provide a random MAC address when joining or reconnecting with a network.
This feature is buried in Settings/WiFi/(Click the Info Icon by the actual network), so it is specific to each network. You’ll need to turn this feature OFF for the WOC Base.
ONCE AND FOR ALL - this is the issue with iOS 14 and setting up your Wyze Cam Outdoor.
MODS - STICKY THIS! I e-mailed Wyze Support and they were useless.
Background: iOS 14 introduced new security features. One of these features was to let your apps discover other devices on the network. If the user opted out of this, your base station will not be able to get set up. It has nothing to do with router settings/IP address.
SOLUTION: Go to Settings >> Privacy >> Local Network >> Wyze. Then switch on the slider (to the right). Start the base station set up process over again. The Wyze app will now be able to find your base station.
You’re welcome. Not everyone has an android or older iOS device, so that is obviously a bad and stupid solution. Again, Wyze Support was useless.
OK, you’ve shut off Private Address on your iOS 14.x phone.
Please go over Post 10, 11 and 12 above with links to seting up the Base, Camera and Troubleshooting. Its been tested and shown to work on all the iOS 14.x
Remove the Wyze App from your iPhone. Unplug everything including your internet router for 10 minutes. After the router reconnects, download / install the Wyze App.
On the iPhone: Shut off the mobile data.
Router: Shut off the 5Ghz WiFi on your wireless router or bridge.
Carefully follow the linked instructions above, starting with the Wyze Base Station.
Some posts were removed or edited that did not follow the Community Guidelines. Please flag posts that violate the guidelines so the moderators can respond appropriately.
You misread. You don’t need an old iOS device. The iOS change occurred with iOS 14 and the Settings > Privacy > Local Network setting still exists in the latest iOS 14.7.1.
8/4/21 1:45 PM PT - This issue has been resolved in the 2.23 app release. If you have been having trouble setting up your Wyze devices, please update your app and try again. If that doesn’t do the trick, please reach out to Wyze Customer Support for assistance.
Just got my Outdoor Cam and base station, use iOS 14.7.1, have done the Settings >> Privacy >> Local Network >> Wyze. Then switch on the slider (to the right), completed the Settings/WiFi/(Click the Info Icon by the actual network)/turn off Private address, and STILL cannot connect.
I don’t have a microSD card reader for my computer so the 8/31/21 12:30 PM fix is not happening (here it is btw) 8/30/21 12:30 PM PT - There is an issue with Wyze Cam Outdoor Base Station that causes it to flash blue without progressing if the firmware is updated when using the wireless connection, followed by plugging the Base Station into ethernet, and then unplugging the ethernet cable to run wirelessly again. We are working on a firmware fix for this. In the meantime, here’s a temporary fix method that flashes firmware:
Download the 4.16.2.24 firmware version using this link.
Put the firmware onto a microSD card:
Windows 10: Right-click in the folder and select Extract All.
Mac: Drag and drop the folder to the root directory of your microSD card. The folder name should be sd_update.
Insert your microSD card into the Base Station and power cycle the Base Station to begin the firmware flash process. The status light will either stay solid yellow or immediately start flashing blue.
Once the flash is complete, the Base Station will reboot itself. Wait until the status light becomes solid blue again. If your Base Station was already set up, it should reconnect automatically. Otherwise, you can set it up again like a new device.
Take out the microSD card and remove the sd_update folder. If you leave that folder, the Base Station will flash its firmware every time it reboots.
Here’s the final response given, so now I/we wait a couple of days or find an Android phone as a possible solution.
We discovered an issue on 8/2 that caused a conflict with some iOS devices and Wyze Cam Outdoor. Our engineers are deploying a fix that will be available in the 2.23 iOS official app scheduled for release this week.
In the meantime, if you have an Android device with the Wyze app handy, give it a try.
