Stuck at 3 of 3 Authenticating - Firmware 4.25.1.060 Anyone else having doorbell issues?
R
R
Are you viewing the camera from the same network itās on, or are you on cellular?
Check your internet speed, and check your WiFi strength at the location of the doorbell.
Try restarting the device in its device settings.
EDIT: it looks like others are having simmaler issues with this firmware issues, Wyze is looking into it and your best bet is to just keep checking for updates with the fix.
UNIFI ![]()
Yea this is apparently an issues many are experience, I brought it up with Wyze so they will look into it.
Submit a log and write down the #.
Go to this thread and scroll to the bottom. Then reply to Arthur from the Wyze Team with your FW version, log number, and a description of your situation.
Yep, same here.
Was working fine for months. New firmware made it totally unreliable.
Same problem here, stuck on 3 of 3 in live view but prior motion clips work.
This is not a signal strength issue as I have 3 Unifi APās in my 1800 sq ft home one of which is only a few feet from the Wyze VD.
I live in a split level home with 3 floors but smaller than a typical 3 family home. I have a Zmodo cam facing out to the street from my 3rd floor bedroom window. My router is in my family room, the lowest level of my home and never drops connection. I also have 3 Wyze Cam Panās inside my home and they never drop connection either. The Wyzedoor bell though is has connectivity issues and I think its this update. It has to be a firmware issue, this is the only one with connectivity issue. A constant Authenticating 1 of 3 or 3 of 3ā¦
Same problem here. Very frustrating.
Performed the āPlease try: 1. Force close app and retry
2. Power cycle the cameraā
multiple times.
No improvement.
Has anyone had any luck? My video doorbell is off line and wonāt come up!
Same, latest version, tried all of their troubleshooting methods and it still gets stuck on step 3
Fix it Friday is here. Suggest everyone click thru and post your issue.
I posted this issue of the doorbell cam, if itās happening to you, you can vote for it
No long duration test on this yet, only about 12 hours, When I power via microUSB (i know it is not a supported way to do it), I have instant connect again.
Posting in the case the devs are only testing via USB power.
*edit, 24 hours in and it still instantly connects.
Armchair debugger - Program checks power state for streaming video load and for some reason on doorbell amperage it is not passing power state check. ![]()
So perhaps its a transformer issue at the chime?
Very astute observation. Made me think
as did @pdclimer. Great troubleshooting. I am not using a house doorbell transformer or existing chime power. I have not experienced this load delay issue. I am using an outlet powered Wall Wart power adapter that I bought to meet the power needs of the doorbell. I wired it direct to the doorbell myself. Perhaps the power supply does have something to do with it. Would love to see if others test on a new power supply to see if it duplicates the solution.
Iām doubting it is a transformer issue (or hardware issue) as the camera was working fine until the last 2 firmware updates.
Agreed that it is a firmware issue and the change\update to that firmware caused the issue to appear.
The troubleshooting is for someone who is using an existing house bell transformer, updated the firmware and now has the problem, to switch to a direct power supply (direct Wall Wart like me or micro USB like @pdclimer) to get additional confirmations that this āfixesā the problem. (Unfortunately I do not have a pre-wired doorbell and so no transformer or powered doorbell chime to test the hypothesis)
With that confirmed āfixā to the problem, it also confirms the hypothesis by @pdclimer and @gabrielescobar that the source of the problem that broke the doorbell is in the firmware coding that checks\regulates the input power.
If we are able to tell Wyze where to look in the code and how to test the unit to duplicate our findings, it may lead to a quicker firmware resolution to the problem.
While it certainly worth checking, Iām not sure it confirms that it is the issue.
Also consider that mtweisenbarger posted āI installed a string hanging from the ceiling about 3 feet from the cameras to trigger what I call āsoftā motion events (the camera picks them up but doesnāt notify me constantly) and had to drop the motion even sensitivity but it works. Even the slightest motion capture will make the live view work.ā
I found that when stuck on Step 3, waving my hand if front of the camera (detection) made it work right away as well.
