Orbs in an empty room and voices in empty room
Anyone else… in night vision I see orbs all over the living room … and sound on I hear multiple inaudible voices talking. Anyone else?
No. But I would like to see what you captured
Welcome to the Wyze User Community Forum @scottlang8888! :man_raising_hand:
Yes.
The cams are pumping out infrared light from the face of the cams. Anything that passes in front of the cam lens will be spotlighted by that IR light at very close range. Most of these are microscopic dust specs in the air current passing within mere millimeters of the lens. Others are nearly invisible flying insects in close proximity. They won’t be seen in daylight because the visible light source is not from the cam.
The voices however is hard to explain without a sample of the audio.
Related posts on “Orbs”:
The cameras can be very sensitive to low level sounds I have found.
My doorbell pro and V3 camera on my front porch can pick up my voice from inside the house.
I also have a V2 and V1 Cam Pan in my basement that can pick of conversations (muffled have you) from the floor above. But, you can easily tell they are voices.
Always looking for the :thinking::open_mouth: video though.
I have the same problem. The camera in my room picks up orbs all the time. But the one in my living room does not pick up anything. so I switch the cameras out and it still just happens in my bedroom. I don’t know what’s causing it. I’m a very clean person. I don’t believe that it is dust or bugs, because if so, wouldn’t it be all over my house?
Welcome to the Wyze User Community Forum @sheree0328! :man_raising_hand:
No. Air currents are the important factor to carry particles. It also may not be dust. High humidity moisture will also produce the same effect.
Yes to both. Are you watching your feed on a Nest Hub? It’s the only device of mine that I can hear the inaudible voices on. It’s likely some kind of interference.
I actually did that on my parents front and back porch last year in Feb/Mar 2023. They are still flying around those lights til this day. I have videos but it will not allow me to upload them because I’m new to this site. How do you get rid of them because they are on my body? As well as my home.
Yes!!! Ok camera upstairs indoors was on, I was downstairs with cat. No one else here. 9:30 am. I saw orb from upper corner of wall come down toward floor. It appeared to be spinning. Then I heard a male voice. It sounded African American. I think it said “go easy baby!!” Then orb circled upward where a larger dimmer orb appeared and both took off. No light from a window is anywhere near. No tv or music on. If it was a bug or dust, then why the voice??? If it intercepted a neighbor voice that’s impossible bc then we’d hear each other. I’m obviously freaked out. On positive note I’m glad the voice was recorded otherwise who the heck would believe me. What was it?? Idk.
The microphone is ridiculously directional, obviously not by design and more by mistake I would guess…
Audio so Good you can hear a leaf drop on a V3 :stuck_out_tongue:
So you could be hearing a neighbor with how the camera microphone is directionally sensitive…
How the heck did you figure that the voice is African American without seeing the person? I wasn’t aware that African Americans have a recognizable voice. :open_mouth:
Must have been speaking jive. I learned about it on the movie, Airplane. Beaver’s mother translated for the stewardess.
My habbibti, no offense. I’m a bit of an expert. I can speak three dialects of Arabic, northern & southern Italian, British, Jamaican north & South American English all have very different dialects. This spirit sounds older & southern & sounds like a black man. I’m wondering if my ex passed and was saying goodbye. :wave: was hoping for an expert in the paranormal. I do not ever hear neighbors. Seeking understanding of the orbs and the message.
I wasn’t offended at all, just dumbfounded.
I know what you mean about the voice. Did you share the video?
I don’t hear voices on my videos, probably because I have “Record Sound” turned off on most of my cameras. Here are some obs in my garage.
And this must be some kind of flying bug in my garage.
Night Vision is on in both of the above videos.
Bugs and dust are totally normal when shining a bright light (whether IR or not). Not sure why so many people get freaked out (not you, but others in threads like this).
My Panv3 that does go into IR mode in my driveway goes nuts at certain times of year when there are a lot of bugs or when it rains. I can’t believe the motors/servos are still alive. Then again the one on the front of my house on a busy street follows cars nonstop all day (neighbors say it looks like it’s watching a tennis match) and its at like 2.5 years now. They at least spec’d some pretty decent motors for that model.
Have considered buying a cheap IR illuminator to mount like 6 feet from the cam but honestly it just isn’t that big of a deal.
I have some cameras from AliExpress that also see these dust orbs. It’s nothing to worry about.
