Wyze Firmware Updates - 2/2/2026
We have some firmware being released today for Wyze Cam v3, Pan v3, v3 Pro, and Pan v2.
For Wyze Cam v3 and Wyze Cam Pan v3 this brings the long awaited RTSP integration.
All these releases will be implemented on a gradual basis over the next few weeks. Just so you know, you will need to be on app version 3.8.5 or above to receive this update, as it includes security updates for both the app and firmware.
Here are the full release notes:
Wyze Cam v3:
Version: 4.36.16.5654
What’s New:
  • Security improvements.
  • Added RTSP support (You will need to update the app to version 3.9 or above).
  • Added ability to change Wi-Fi without device reset (You will need to update the app to version 3.9 or above).
  • Improved facial detection resolution.
  • IoT connection stability improvements.
  • Bug fixes.
Note: You will need to update the app to version 3.8.5 or above to receive this firmware update. App versions lower than 3.8.5 can’t connect to this firmware due to security improvements in both the app and the firmware.
Wyze Cam Pan v3:
Version: 4.50.16.5654
What’s New:
  • Bug fixes.
Wyze Cam v3 Pro:
Version: 4.58.16.5654
What’s New:
  • Bug fixes.
Wyze Cam Pan v2:
Version: 4.49.16.5654
What’s New:
  • Bug fixes.
@WyzeJasonJ , the live view issue with cameras in groups, has it been solved?
Still no audio on the browser for Wyze Cam Pan v3 :roll_eyes:
Anyone with this model, be aware that this firmware broke my spotlights from working automatically with motion from the settings area. There is a workaround to setup an automation to control the spotlight instead that is working well for me. So if your spotlight stops working automatically, you can try that.
I just reconnected my cam pan v3 and it worked fine. Then it said I have a firmware update. So it downloaded and installed NOW it won’t connect to WIFI no matter what I try.
Haven’t seen these yet for my v3. Will be on the lookout.
Thanks.
@WyzeJasonJ
What is the purpose of having the firmware on beta and then getting it released to the public without fixing reported bugs?
Why even bother…
Thanks for the heads up, I’ll leave my V3 Pro on its current version for now.
I will be watching this forum for positive comments on v3 firmware 4.36.16.5654.
If I see positive comments, then I will update to App version 3.10 and then v3 firmware 4.36.16.5654.
I have the iOS app 3.10.5 (2) and the .5654 firmware on all my V3 cams. I updated them about one hour ago and no :collision: or :fire: yet.
laughing
:exploding_head::wink:‍
How’s your group view? FW .5654 broke mine :frowning:
I don’t use groups. :grin:
:astonished_face:
So, I’ve had one of my Cam Pan v3s on the beta firmware to test the RTSP. If I now leave the Beta, will the one currently with beta firmware be able to move to the new regular firmware version OTA? If so, will it keep its RTSP settings?
Has the issue with RTSP firmware not working with Tinycam been resolved with this release?
Yes and yes.
Have no clue as I don’t use TinyCam.
I agree with @habib’s answer and would also note that there has been no apparent version change between the most recent Cam Pan v3 β firmware and this production release:
I haven’t seen any news about the tinyCam Monitor situation. I would tend to agree with others who think that the developer will probably release an update at some point that will allow it to work with these Wyze firmware changes, but that’s just speculation on my part.
Having the same problem over last several days. Works fine on a web browser but not on iOS platform. Very frustrating. Constantly rebooting, reinstalling app, powering on and off and nothing seems to help. What is being done bout this?
Nothing as far asI know. Only way to find out would be when Wyze pushes new firmware.
