Wyze Cam v3, Pan v2 & v3 Pro Firmware Beta Test 5/17/2023
Please read what you write before you hit “Reply”. Dude you make no sense. Sorry man but I have no idea what you are saying :slight_smile:
Exactly so don’t reply. Mind. Own
Dude, If you don’t like Wyze, why are you here? And I can reply if I want to. If you don’t like it you’re free to leave or block me. You don’t bring anything useful to the forum. What are your issues? What have you tried? Just complaining and complaining is useless to all that are on here. I spent 19 years as a senior mod for Motorola’s forum. I know what kind of person you are already. Just posting rants is useless and usually gets you banned. I’m blocking you anyway since I’m sure you won’t learn.
By the way I have over 30 devices from Wyze. I’ve never had any problems with them. A quick power on and off fixes most little things. I’ve used Ring devices as well and was a mod on their forum as well. Their customer support was lacking and the products were expensive. Do you know what I did? I said sorry I have to leave the forum and I stopped using Ring. I did not go off on them. I just left. Very simple really. Wyze has been nothing but great for myself and many others. And don’t start with the I’m a fan boy remarks as I am not one of those. If the company, products and customer service is good I’ll stay. If not I will move on, but without any comments.
Thank you very much. I use to mod at 2 companies at one time so we got to test many devices and apps. I used to do troubleshooting and of course betas too. Now I just read the posts and sometimes my old modding of forums kicks in still. I think I just updated 15 cams today by bulk. I only had one V3 pro cam not update. I was able to update it after I took it offline remotely with my Wyze outside plugs and turned it back on. It’s great to be able to shut the power off and on without having to move from my seat or climb a ladder. This is a great forum I see with many supporters. Not many trolls as well. Thanks again :+1:t2:.
Are they aware of the issue, and are they working on a fix for it?
They shouldn’t have to research a fix, they should just undo the thing they did to make this issue start in the first place… Posting here because this is the version (beta 5/17/2023) that started the issue.
Since you reported it in the Beta Thread… The only version that can be modified and updated, yes. I’m confident you have made them aware of it.
I suggest you flash back to a prior firmware version that works for your needs.
SlabSlayer
Do you know if they are working on it?
I just took one back to the latest public version, and it didn’t fix it.
4.58.11.4679] (June 8, 2023)
I have confirmed we have to go back to 4.58.0.3210 (December 12, 2022) to fix the problem.
And there are a lot of fixes between now and then that we would not want to be without.
  • Improved Internet connection
  • Improved the IoT connection success rate
  • Improved the Event Video replay success rate
  • Fixed a bug that caused the spotlight to always stay on
  • Fixed a bug that prevented viewing Playback video
  • Fixed a bug that impacted WPA2 and WPA3 mixed network connections
    Plus any of the beta fixes since then.
We would love to have some kind of update…
Thanks,
I do not have any information on this particular bug either for the V3 or the V3Pro. I run my all my cams with the status light disabled 24\7 and only enable them to test. I am currently on assignment, so I cannot physically access my cams.
If it didn’t get fixed in the two production releases, 4.36.11.4679 and 4.58.11.4679 respectively, released after it was reported in this Beta thread, and it is still present in the current Beta Firmware versions in active testing, 4.36.11.5614 and 4.58.11.4847 respectively, then detailed posts describing the bug needs to be posted in those Beta threads and every production release thread and Beta release thread that comes out with the bug until it is addressed. It wouldn’t hurt to also include it in the monthly Fix it Friday thread.
