Wyze Cam OG - Released 1/17/2023
The Wyze Cam OG connects to your wifi network. No base station required or needed.
Also for those interested, the Wyze Cam OG AMA just started. Visit https://www.wyze.com/ and scroll towards the bottom.
Yes, this is still available.
I have not tested that to know first hand.
These do not need to connect to a base station.
Will the cam group streaming problem be fixed in next app update to cover this new cam ? I am still using the previous 153 version.
Which problem? The Error -1 issue has been fixed.
This is one of the top 10 vote getters on the Wishlist. Please hop over and vote and comment on it here:
@WyzeJasonJ, Gwen
Can we buy OG in Canada now?
Wyze has two lines of cameras: wired and battery powered. Each has pros and cons. All of the current cameras are outdoor weather rated. Just because a camera is wired does not mean it is useless for outdoor use. I personally have five V3 cameras mounted outdoors where I was able to run power to them.
Battery powered cameras have the advantage that they don’t have to be wired to a power source, But they have the disadvantage that you have to take them down to charge the battery periodically. Additionally, to conserve power, battery cameras are not capable of, for example, recording continuously to the SD card among other necessary power conservation measures. For these reasons, I will always opt for a wired camera for any location at which it is at all feasible to run power. That said, I do understand that there are locations at which running power is not feasible. It is for that reason that Wyze also produces battery powered cameras.
Answered above:
When will it be available on the Wyze app so I can use my Wyze Cam OG?
I am being told that it is already in the app. No app update is required. It will be enabled server-side by sometime this evening.
I have to reload app to get group viewing working.
I have Wyze App on my phone…
For any wired camera, you tap View Playback in the app. While the SD card recording is playing back, you tap the Record button on that screen. When done, you tap the Stop button. The video segment that you just recorded is saved to your phone’s camera roll (Wyze album).
The downside is that you have to wait for the recording in real time. There is a top-10 Wishlist item regarding direct download of SD card clips. Please hop over and vote for and comment on it here:
https://www.reddit.com/r/wyzecam/comments/10eh9gv/comment/j4rk2ui/
This issue is still in the progress of being fixed.
We are, and I am the one who posted that lol.
A few select answers from today’s AMA Livestream for the OG cams:
Also said verbally (though the following are paraphrased and not verbatim):
We could do 5x 7x so let us know [what other magnification preferences you may have for telephoto lens options in the future]
Lamp socket can’t power 2 cams, but it can power 1 (but still not control the lamp socket); however the floodlight’s second USB port can power 2 of these cameras.
