Wyze app 3.0 & Cam v4 Firmware Beta Test 6/3/2024
Wyze Scale S and New Beta Software
The new Beta SW has an icon for Scale S but does not connect. Everytime I need to “Add” an new scale and then if connects. What are the issues with this. The Scale Icon does nothing when clicked on.
[Mod Note]: Your topic was merged to this Beta announcement topic for better visibility to Wyze.
My only feedback on this so far has been:
ticket (3941110)
(2:19:02 PM) Milky : Oh, I see. No problem. Right now, I’m going to forward this issue to the team along with the log ID for further checking I recommend using the public app for the time being.
Android Push Notification Sound setting doesn’t work
I am running the Wyze Beta app v3.0.0 (b489) and despite setting the Push Notifications to use one of the “Wyze” specific sounds, it only uses my default Android notification sound.
Samsung Galaxy S24+ running Android 14
Me too, S23 Ultra, I did post but just decided to pick a specific sound sound I liked in notifications, apps, Wyze beta, notification categories. If like S23, notification categories may have to be turned back on. They’ll fix it sooner or later.
Not sure if this was mentioned, but in the 3.0 beta there is no way to arrange individual cameras in the group. The three lines on the right of the cameras are gone.
I’m seeing some weirdness or I’m nuts,
Opening live view on a cam, settings detection settings, detection zones, opens a different camera settings zone.
I’ll keep checking but seems able to be repeatable in my Samsung android, cache cleaned.:face_with_spiral_eyes::dizzy_face::stuck_out_tongue_winking_eye::thinking::person_shrugging: Click thru screenshots.
I just tested my 5 cams and got the correct detection zone picture for all of them. Pixel 7
I did have a different camera’s thumbnail show up on my doorbell pro for a few hours but corrected itself.
In my personal experience, I remind myself that these aren’t mutually exclusive :joy: But in your case, you made a great find! Let’s see if anyone can reproduce it.
Is that an OG camera this happened on? Is that other camera view one of YOUR other cameras or a past view of that camera, or some other view you don’t recognize at all?
Assuming it is one of your other cameras, is it also an OG camera? If so, is it the view of another linked OG?
Look at you smarty pants! :rofl:
Thanks, I was going nuts trying to find out what happened :joy:
If you go to the group settings and select devices, you should be able to move them.
Tap on the group then the settings gear at the top right. Then select cameras in group and you will see the lines to move or change the order.
Both regular OGs, and not linked any other OG cameras. It would happen then not happen after a couple tries, that was the nuts part. :joy: I’ll explore the others, I have all OGs, 2 V4s and an OG tele, 3 pan V3s.
When I have time tonight. I hope someone can reproduce it. I’m not ready for Cuckoos Nest and a labomomy just yet.
A clue arises though, so far, might be following the last cam I live viewed. I’ll keep poking at it for some hints.
Just switched my iPhone back to the production app. Unable to turn motion detection on/off on cameras. Just switches back to what was set.
The problem is that I was looking for the lines. You both are correct, the lines are there but my aging eyes could not see them, they’re so faint. Once again, really poor interface design :frowning:
R23u2kS7fEsb3LgbWiM3Ja1
Light gray on white??? whoa
tenor
It must be an iOS issue, I will have to look at those device. Here is what it looks like on Android:
That is exactly what I was looking for :laughing:
Looks normal on my iOS. Which the Android does look darker.
Might be a resolution thing. Just trying to think outside the box here. My Door lock loses the top part of the lock when I am at a larger resolution, but only when it is unlocked
I think it’s a color palette thing. The icon is there. It’s just the wrong color. Ref zoomed icon capture of habib’s screenshot above.
