3.0 App Beta #2 Test 7/8/2024
I started rearranging groups from the bottom to the top, and while scrolling through tons and tons of devices (I have a lot), the app often closed and reset the item back to it’s original position. It was almost like the app kept crashing or minimizing if my finger went close to the top. A few times it stopped part way up the list and parked the card even though I didn’t remove my finger.
Some of them went fine to the top the first time, but some took as many as 6 attempts before I finally got it to the top.
Anyway, I will rearrange some more again later today when I wake up (about to go to bed), and then I will retry adding a new group or device and see if it does the same thing. :+1:
you need to uninstall the existing beta first. Especially if you installed the preview one.
Latest update automatically installed on my S24+.
I’m having multiple issues now:
Can’t select any camera from the Favorites tab to get to it’s detailed page. All it does is refresh the tab.
Events are not there. No events down in the log even for days before the update.
Filters for events is also acting up, doesn’t show any cameras, then all of a sudden they appear. Selecting the ones I want does nothing, no events show up.
I have an S24+ as well and not seeing the issue. Can you try the following:
  • Start the App and go to the Account Tab, scroll to the bottom and select App Settings, then tap on Clear Cache
  • Back out one screen to return to the Account Page and scroll to the bottom. Select Log out. (Make sure you have your password and 2FA)
  • Long Press on the App Icon and select the App Info (small i in a circle)
  • Scroll Down to Storage and tap on it. Bottom Right click on Clear Cache. Not Clear Data.
  • Close the info page down and restart your phone.
Then Logon and see if things are working.
Also, can you provide which camera you are seeing this with or is it all cameras?
Now it’s working fine.
Does the app need time to rebuild it’s cache after an update?
Possibly as there were a lot of changes. I tend to do the steps with Beta releases when I see weird issues.
Glad you are working now
Wyze beta IOS app 3.0.0.9 on IOS 17.5.1 using iPhone 13 pro max. Again tested SDCard access for Wyze floodlight pro, still no SD Card menu item. This behavior is since IOS beta app 3.0.0 (7).
If nobody else is finding this, maybe it is very specific to my setup??
Wyze beta IOS app 3.0.0.9 on IOS 17.5.1 using iPhone 13 pro max Sprinkler FW 1.0.11.
The Sprinkler home screen show zones as completely saturated with moisture even when not much of rains and no sprinkler activity. Individual zone shows 0 saturation of moisture.
This was observed since beta 3.0.0 (8).
Just discovered this one. On Android only, I can’t pinch zoom on any V3 camera. I can pinch zoom on V2, original Pan, V3 Pan, V3 Pro, V4, & OG-Tele. But all 17 V3 cameras can’t pinch zoom. All of the V3 cameras are v4.36.13.0416 except one that refuses to update and two with RTSP firmware
iOS app 3.0.0 (9) on iPhone 13 with iOS 17.5.1
Android app: v3.0.0 (b505) on Motorola Edge with android 13
V3 cameras 4.36.12.9357 or 4.36.13.0416 or 4.61.0.3 (RTSP)
V2 cameras v4.9.9.3006
OG-Tele cameras 1.0.80
V3 Pro cameras 4.58.13.0416
Original Pan cameras v4.10.9.3006
WYZE SWITCH ADDTIONAL CONTROLS - Unable to change, app dumps out of screen.
Still can’t update Wyze Switch Additional Controls - I am unable to change the Dbl-Click, Triple-Click actions.
LOG Submitted: 1475348 (with video example in submission).
@WyzeAndy @WyzeJasonJ @WyzeDesmond @WyzeRyan
I am testing the 3.0 Beta App #2 on the Pixel Tablet. As reported before Pixel has added a resolution setting to the apps so that it can take advantage of the screen real-estate. However, as you can see from the images below there are some basic issues.
The cameras on the favorites page seem to compress the camera container, but the actual live stream will extend beyond the frame. See the images below.
I did create a log for review: 1474791
Also note, when I pick app default, the camera streams look better, but the screen is pushed to the complete right and only takes up about 1/3 of the page.
Although on a phone this layout looks great, when on a tablet, only allowing 2 device icons in a row and 1 camera in a row does no lend itself to a clean look. I would rather you keep the same size button as shown on the phones and maybe allow for 4 to 6 across the page. For Cameras, it would be nice if you keep the size of the camera from the phone and allow that on the tablet in landscape. then on one line, you could have 2 to 4 cameras being shown cleanly.
My Sprinkler controller won’t allow me to look earlier than Jul 7-13. I wonder why our weeks are different. Mine is Sun-Sat and yours is showing Sat-Fri. That is weird. Also, I’ve never had it not be able to show me soil moisture prior to 2 days ago, and it almost always shows me the estimated moisture for the next several weeks in the future. Now it is locked showing only the last 2 days like this:
That’s not normal. It’s only showing Sunday and Monday, not even Tuesday or Today, so there are 2 days missing and no future days, and not showing anything from last week. This is a bug. Between what @Chandan.Dutta is seeing and what I am seeing, it looks like the moisture saturation feature is frozen/broken in some way on this app version.
@WyzeSzhang Log 1476050
The > sign is back on IOS Beta 3.0.0 (9) app. The > color is faintly visible if the plug group is showing green when plugs are on, suggest the symbol > color has better contrast with background green.
The > color contrast is better with the plug group background grey when the plugs are off.
Is anyone else having trouble zooming in on V3 Livestream? I used to be able to double tap the live stream to zoom in, or pinch to zoom, but now it doesn’t work for my V3’s with this 3.0 Beta 2 app. I can still do it with other camera models though, just not with the V3’s. Can someone else please confirm this?
I added a floodlight pro today and it went to the top of my device list
@carverofchoice yes I am seeing this as well. No pinch to zoom on v3s. Double tapping creates a black screen for me.
See my post 30. Yes, Zoom not working on V3 cameras (only).
Not sure if this was a thing on test 1, but I noticed on my Wyze 4, if I want to change the resolution, if I click the box on the top left, I have to keep clicking it till it shows the one I want. However on the 2.5 version if I click the resolution button I get a pop up asking me what resolution I want. Also this only happens on my Wyze v4. My Wyze v3 and pan v3 doesn’t do this.
Also I noticed on the Wyze v4, on this test version it says 2.5k vs the 2.5 version of the Wyze app shows 2k.
Also just a note, on the beta version I am able to do the pip with it, I know this something that seems to only work for some people so not sure if this is all connected.
:man_facepalming: Doh! Sorry, I even read your post and just totally forgot about it because I was too busy to test it when I first read it! Good catch.
@WyzeSzhang we have 3 confirmations that V3’s don’t allow zooming anymore, either with double tap to zoom or pinch to zoom. Hopefully you guys have time to get that fixed before the Release Candidate.
I am now as well. Beta release 2 installed.
However, not sure I tested zooming in on the v3 much
