Wyze app 3.5 RC test 5/1/2025
Wyze app 3.5 Release Candidate:
Versions:
  • Android: 3.5.0.b659
  • iOS: 3.5.0(5)
What’s new:
  • Fixed the missing SD card button on the Floodlight Pro live stream page. (iOS)
  • Bug Fixes
Updated. No issues to date.
Same here. :slight_smile:
Did the App update successfully.
However I do not still see the SD Card button.
Any suggestions?
Just started using the beta version app, and i gotta say the video scrubbing section at the bottom is a bazxilion times better!
Uninstall.
Reboot phone.
Reinstall.
Is what i would do, if you hadnt already.
Which cam(s) are you running?
Just been experimenting with some OGs on the latest production release and I’m surprised how sluggish they are. Scrubbing around on the old v3 style interface is brisk and reliable.
Running 3 V4’s.
I also have 2 ogs and 2 v3Pros. But cant use them any longer due to living with a toxic person who works in telecommunications. So WPA3 is a game changer for me
Thanks. I should have specified I’m talking about scrubbing around the SD card footage. The cloud Events are fine.
Scroll to the left in the area that the [Take Photo] icon, [Record] icon, [Album] icon, [Turn Off] icon are at. Its not obvious that section is scrollable, but it should be.
Sorry, I also should have specified I was comparing it to the last stable release of the app. I believe scrubbing was up and down in that one.
It took me a couple of days, but I was able to update to the RC Android version.
However, I noticed that 2 “issues” I have previously reported are still present.
The first is the obnoxious little floating icon on the Automation screen. It was gone for a little while, but now it’s back. I would like to have the option to disable it, similar to the Submit Log option.
Second is the exit app when I use the Android “Back” arrow at the bottom of the phone screen. Previous app versions would take me to the app Home page if I was in another page like Events. Then a second press of the back arrow would exit the screen. Now it is “one and done.” I would like to know if this is intentional or a bug. I was not given an answer the last time I asked.
I hope you get an answer, and I’ll keep plugging this:
My app firmware updated to To 3.5.0 updated automatically and nothing negative has surfaced here.
Douglas
Sometimes the on screen controls do not load while scrubbing the SDCARD footage. The scene loads, but no pause/play, 30sec back/forward controls etc. Its happened a few times, although, i am not sure how to trigger the bug yet.
Also, pressing the SDCARD icon to load footage will frequently crash/force close the app.
Battery :low_battery:
Phone was super hot all night and this is the overnight battery usage
