Wyze app hotfix 3.2.1.581 - Released 10/28/2024
Today we are releasing hotfix version 3.2.1.581 of the Android version of the Wyze app to fix a few bugs we ran into.
Read our Release Notes: :notebook:
Thanks @WyzeJasonJ .
My 580 works great. I hate to fix mine if it works fine.
Glad your on it. Thanks @WyzeJasonJ.
As an aside. It would be great if the release could reference what bugs were fixed.
As @ssummerlin said.
Ya think?? :astonished:
/edit
ā€˜Bug fixes’ ex this one…
Insufficiently ā€˜hot’ I guess. :cold_face:
Reference: Cam Plus Lite Person Filter Unavailable, directs user to Cam Unlimited subscription opportunity when selected.
How about IOS?
I think you got yours a few days ago. :blush:
I guess he’s right! :slight_smile:
Don’t forget to VOTE!
Since then none of my Cam Pan v3s recognize their SD cards. And I cannot view events. I have tried deleting the cameras, reformatting cards, inserting new cards and no luck. Seems these cameras a re now useless to me. Just bought 3 black in July. And cannot return them now. I have tried to exchange, but been told I cannot do that either. I have seen in the forum that there have been hardware failures in these cameras and others were allowed to exchange them for new. I have been told I cannot. :man_shrugging:t3:
Is it this issue? :point_down:
What if you navigate directly to the camera’s Live Stream screen and try to look at the microSD card recording timeline? That seems to be the suggested work-around for now, until Wyze resolves this, perhaps with a back-end change as they’ve apparently done before.
@pwoods30167,
You seem to have an extreme case. Some of us are watching intently for the root cause of the SD card issue.
If I could suggest waiting for this hot fix to appear on Google play. We do not know what bugs were fixed.
After the hot fix, if your still seeing the same issue then let us know. We will need a lot of info
Sometimes. Usually get ā€œFailed to load from local storageā€
I often experience that as a self-resolving issue, going back through several previous app versions (including v2.5x). I’ve been seeing that for months. I’m puzzled by that and don’t understand why the app briefly shows me that message even if it’s going to go ahead and play an event. :confused:
You need a subscription for that! :joy:
581 just appeared on Google Play.
Testing
Same issue with this latest Wyze Android app hotfix v3.2.1.581
ummm,
Where did the floating paper airplane for sending logs go?
I can’t even find the setting now…
Was about to send a bunch of logs for multiple cameras, and it is gone…
3.2.1 (581)
I moved your post to the correct topic. You don’t see the submit log icon because 3.2.1 (581) is not a beta release. You can still submit logs via Account > Wyze Support > Submit a Log or via the direct device support links.
Hi Jason,
I know I am sounding smart a$$ed, but wouldn’t it be easier on everyone and much less to type…?
Instead of saying
ā€œRead our Release Notes:ā€
And providing a link, to just say
" * Bug fixes" ?
Since that is all the release notes says?
Hi Seapup,
Thanks, but help me out…
Are you saying that the floating airplane is only on the beta versions?
And I am in the beta program…
