2.32 app RC test 6/9/2022
VERSIONS:
  • Android: 2.32.0.b150
  • iOS: 2.32.0(17)
WHAT’S NEW:
  • Added support for turning on Power and Lighting devices for X minutes as an action in Rules
  • Fixed a bug that prevented Cam Plus Lite devices from using AI triggers in Rules
  • Fixed a camera group crash issue on Android 10 devices (Android only)
  • Fixed Bluetooth Wyze devices crash issue on Android 12 devices (Android only)
  • Bug fixes
Just showed up for iOS, will begin testing it.
EDIT
Just tested the on for x minute Rule. I set up a rule as follows: When my outlet goes on turn on my color bulb for 2 minutes. It does go on, but never goes off.
Log submitted from iOS: 607851
App Version: 2.32.0 (b17)
Rule Name: Test Blink (Please ignore, I repurposed this rule after testing the Blinking)
Bulb Name: OFC CB
Images:
Came here to say the same thing… light comes on… doesn’t go off.
I am very excited for this rule… it means you can turn lights on using a camera and not need a 2nd action to turn them off… same goes with motion or doors or whatever. I eagerly await this rule!
-Scott
I do have 1 caveat… I’m not on build # 150… I am still on build Android: 2.32.0.b148…
but I see the rule choice. I should probably get this version of the software first… I will comment back when I get it.
Same here, so I tested on my iOS which is on the latest RC build and still the same results
EDIT
Just installed the Android app and did a similar test with a motion sensor and bulb. The test was successful. When motion was seen it turned a bulb on. In 5 minutes the bulb went off.
Will do more testing to see if it continues to work with different timings. I will also compare to iOS
Did you install 2.32.0.b150 for Android? I’m still not seeing the update. :confused:
Yes, it was available to me this morning
Thx for confirming. Need to test a bunch of stuff in this RC build so still in wait over here. :+1:
Anything I can test for you?
I am testing the Camera triggering a Bulb for x minutes for Carver. Then do the same test but go back in front of the camera and see if the counter starts over.
Spoiler - It did restart the counter when I used a motion sensor. So now it is the Camera test. :slight_smile:
Sure! This is an important issue that probably didn’t make the build:
It’s a simple test. From an Android device, pull up a live stream for a cam type other than v3. Tap anywhere in the live stream space.
I am using Android 12 and don’t have the issue. I tapped on the Live Stream on a V2, Cam Pan v2, and WCO v2, all did not have issues. Double tap does a zoom in.
I did see that they corrected issues related to Android 10
Thanks for testing! Do you have a pre-Android 12 device to check this issue?
I will try with my ONN Tablet, I think it is pre 12.
EDIT
@Seapup
Just test on Android 11 and everything functions as expected. I don’t recall having this issue in the past, but mainly use Android 12.
Note: When I was testing in the past and encountered issues with my BT connected devices, I ended clearing cache, uninstalling the app, restarting the device, and then installing the app fresh. Once I did that, it worked without issue. Curious if your problems would go away if you did the same.
Just wanted to update everyone on the Turn on for X Rule Action:
  • My testing with Android 12 using b150 worked as expected. I tested the following:
    • Camera detecting motion turned light on for 5 minutes and then it went off
    • Motion Detected turned lights on for 5 minutes and then it went off
    • Plug turned on causing the bulb to turn on for 5 minutes then it went off
Basically, I was testing any Trigger with the action for the bulb being Turn on for X Minutes.
For the Good News
If motion or trigger even occurs again, the counter or countdown clock resets.
I not only did that, I started fresh with a burner phone. :grin:
Well then. It is working on this version. :slight_smile:
That’s good news! Thank you for testing. :smiley: RC still not available here, but I’m sure it will show up sometime today.
Will be interested if it works when you get the update as well.
Argh, the app just hates me I guess. I don’t know why it works for you but not me. Maybe it only works to reset the timer for motion but not no for person triggers? Maybe it’s because I’m using RC app and you guys are on beta? So weird. Maybe it’s that I’m using Cam Plus Pro on that camera? Maybe because I’m having it do a group instead of an individual bulb.
None of that should matter. I verified the initial trigger turns on the bulbs, but subsequent triggers aren’t resetting the time (for me).
I guess I’ll have to start small and add 1 change at time until I figure out why it’s only not working for me.
