2.28 app Beta Test 1/13/2022
Now the 12 Pro Max has the same detection zone display issue as the 13 Pro and 13 Pro Max.
The display should be full screen like the griddles of the zone detection are.
This is the same issue in all landscaping mode. I tought it was normal because at the right, there are icons BUT when you enlarge the display (zoom pinch) to make it full screen, you still see the icons because they are superimposed on the screen.
Landscape view from live viewing:
Pinching zoom
What I think: Changing the resolution in all landscape mode will fix the zone detection issue because the detection grill is displayed in full screen.
@WyzeAndy
@WyzeBaohua
How do we use Test Mode for Lamp Socket?
Better shots for you, i selected areas in the black bars then rotated
Check my previous post about the black bars. I think if they change the resolution in lanscape mode to make the display FULL SCREEN (without black bars) will fix the detection zone griddle issue.
@WyzeAndy @WyzeBaohua and Wyze Team
I wanted to provide Kudo’s on this release as the new additional features are a welcome change.
Some Fixes
  • Doorbell GUI seems to be shifted down and is easier to get to settings
  • My v2’s seem to be functioning without going offline
  • My Startup times for the Camera’s seems to be quicker
  • 2FA GUI Page not showing
One New Features
Issues found so far
  • So far I have only found 2 issues on Android shown here:
  • @gyzmo has reported and found this issue existing on iPhone12 Pro Max, iPhone 13 Pro, and iPhone 13 ProMax. This was confirmed by @R.Good and myself
Man, this update is STILL not showing up for me :sob: I’m about ready to go download it from a mirror site…
@spamoni did you ever figure out last time why everyone but you was getting the last beta app update? Somehow it looks like I took your place this time and I’m the one not getting the update for some reason.
I don’t think mirrors host beta apks. But if you don’t have it by tomorrow, shoot me a PM and I’ll package it for you on my server.
I worked with Andy and he did a closed invite for me. That fixed it. He was not sure why we had to do that.
@WyzeAndy
On iOS when trying to create a trigger rule with the climate sensor I cannot use the scroller to select a temp
This operated properly on Android, as seen below.
Not sure if this is intentional, but both Android and iOS no longer has the Order History Menu Choice. Some of us used to send individuals to Account area for that option, especially when we could not find the orders on the Website.
Is this intentional or an oversight?
I don’t currently have a beta app version for iOS loaded, but did notice a slight discrepancy with scrolling selection fields across the production apps:
  • Under Android, you can swipe anywhere to the left/right of the selection to scroll.
  • Under iOS you have to place your fingertip exactly on the numeric digit to scroll.
Are you sure you have your fingertip exactly on the numeric digit area? If you miss, you have to wait for the screen to stop moving before attempting a retry.
Validated with @spamoni prior to posting but went back to look again per your provided details. Either iOS does not care for my guitar playing meat hooks or the scroller doesn’t want to work for me :wink:
Yep, looks like a bug to me. :+1:
All of my Android devices don’t seem to mind calluses. On iOS devices, I have to use my right hand and/or left thumb. Which is why I rarely use my iPhones and iPads.
Noticed this last night. I was allowed to add cameras that are flashed for RTSP to CamPlus. Previously, cameras that were flashed for RTSP could not be added to CamPlus (there is a work around).
Here’s the details. I have 29 operational Wyze cameras at home (16 V2, 2 pan, 13 V3). Almost all have been flashed for RTSP. I finally gave up on the grand RTSP experiment (it works too poorly), and Wednesday evening I flashed 19 cameras back to standard firmware. Some were on CamPlus with the RTSP workaround, and some did not. It was getting late so I did not bother added some of those cameras to CamPlus until last night. Much to my surprise, I was able to add the remaining cameras that were RTSP flashed, but had not been on CamPlus to my unlimited CamPlus. Also working in live web view. Don’t know if this is new with this new beta - v2.28.0 (b99) n my Android, but I had not been able to add RTSP flashed cameras to CamPlus (except using the work around).
New one… Now when opening the Wyze Beta app on Android I am presented with the below error. @spamoni has also validated.
Thinking this may be due to the climate sensor group I tried to delete the group to see if it cleared the 1001 error, I got an error message the deletion failed. @Seapup are you seeing this same behavior?
Log ID: 436410
Update: Getting this on iOS now as well. And similar to Android I cannot delete the climate sensor group on iOS. LOG ID: 436420
I see we have the same manicurist :joy:
I just updated my app and now when I go into the app I get Error 1000. I tried deleting the app and reinstalling. Same. Updated to latest IOS on iPhone X . Same error.
And now all the sudden without me trying to delete again the Climate Group has deleted from both devices.
Android
iOS
I was able to go back in and create the group and now no longer seeing the 1001 error in either device from the above thread.
Thank you so much for your feedbacks! We have fixed the Error 1001 issue. Please let me know if it has not been fixed on your end. Thanks!
Yep, Mine is back. Thanks!
