Glad to see the ever increasingly useful tweaks to the app, but the last update did something to all my group cams. They appear offline and when enabled they turn themselves back off in a few seconds. It’s like a digital version of that useless box that turns off its own tile switch.
I’ve been a beta tester since the beginning, but this particular Android beta update is not showing up for me. Strange.
@WyzeBaohua: I noticed something odd and exciting while adjusting the settings on a v3 cam today. This is observed only under the current beta app for Android v2.28.0 (b99) and only on 1 out of 30 v3 cams, all running current production firmware 4.36.8.15. It appears that implementation of this #wishlist item has somehow found its way to one of my v3 cams:
I’m confused as to how this highly desirable feature occurs only on 1 of my cams. If you pushed it somehow, please do not remove it. Push it to all of my cams! If the push was intentional, please let me know, as I have a few bugs to report. If you are as confused as I am, I’ll just wait until the feature is completed and enjoy being able to indepedently set AI Event types and AI Event type notifications on this cam. And kudos for implementing our ideas!
If you follow @spamoni4 's instructions in post 39-ish in this thread you should see it get added to all your other V3’s too (using Android at least).
Say what??? Was going go eat… time to do some playing! Thanks!
Might need to update that wishlist item to roadmap and testing if it’s already in the 2.28 beta app being tested.
Just eat and pull up all 29 other cameras… turn off, back out, turn on, turn off, back out, turn on. By the end:
Nice! All you have to do is toggle off all Smart Detection AI settings under Event Recording and immediately toggle them back on.
The non-callused hand/finger is going to get a workout this evening.
LOL, The only way I figured this out was when my iPhone showed a different setting than thew Android. At that time, I figured the settings were not being refreshed or set appropriately. So now I make it a habit to check this first after all App updates.
It does seem to work. It will only notify based on the selection you have for AI. Downside, if you don’t have anything selected except AI then you don’t get notified since no AI items are selected.
Got it working v2, v3 and Pan Cam v2 cams with CP, but not WCO cams. Anyone get this working on a WCO cam with Cam Plus?
This seems to not work for the WCO and VDB v1. I don’t have the VDB Pro to test against.
The v2, v3, and Cam Pan v2 does allow for AI Notification settings
Thanks! Now it’s time to eat!
No luck on the VDBP.
Thanks for checking
I just received the 1001 error while loading iOS Beta app 2.28.0 (a5).
Next load was fine.
Log 438055.
Same problem for me on android 12 pixel 5a
not sure how I got the beta app but I complained that the top back arrow and settings gear were in the notification area on the top of my screen . Next thing I knew I had the beta app and the issue was fixed
next day after beta update the cams show off on homepage when they aren’t and will switch back to that view even if turned on in the homepage view after a few seconds
