Today we are releasing firmware 1.0.24.11 for the Wyze Duo Cam Doorbell. This fixes a bug that caused the unit to crash along with fixing some microSD card issues and other bug fixes.
Read our Release Notes:
No one has tried the new firmware yet? ![]()
Yes. I’ve been this running this version since the beta release. No notable issues as far as I can tell… However, I still set it to automatically reboot at least once a day as a preemptive measure since I saw intermittent network disconnects in the prior firmware version.
Would be interested to know if the new firmware fixes problems without having to reboot the floodlight everyday. That’s what I’m doing now to temporarily fix its issues.
I’ve had this since beta too, and it fixed most of the issues I was seeing, including most of my SD card playback issues (I was getting some intermittent blank spots which I think were caused by it going into suspended status when it shouldn’t), and it fixed that, but sometimes I am having trouble viewing the playback (sometimes it will load and sometimes it won’t), but I haven’t heard others reporting this issue, so it may be an isolated situation related to my card or something.
I don’t have an issue with SD card playback; if it recorded on SD, which is an issue that rebooting temporarily fixes. But not to turn on when there’s motion, that’s a big one. Even cheap dumb floodlights do that effectively.
I have another floodlight pro, and that one has an earlier firmware. It has no problems.
Were these posts intended for a Cam Floodlight Pro firmware topic?
Oops, can these be moved?
A Moderator could do that. You can flag your own posts that you want moved, select Something Else, and then provide a link to where you think they belong. They’re good about responding to requests and moving things. ![]()
There are several posts from other people as well. It’s better for a moderator to move the entire sub-thread.
Yeah, and delete my comments in the process. ![]()
I had something similar within the last week and I fixed it by clearing the cache. Maybe the cache is causing a conflict somewhere.
I already cleared the cache; several times. The weird thing is, it only started a day after I updated the firmware.
