Wyze Cam v3 & Pan v2 Firmware Beta Test 3/23/2023
Wyze Cam v3 :
Version: 4.36.11.4073
What’s New:
  • Fixed a bug that caused Playback to skip the first minute of every hour
  • Fixed a bug that caused Playback to stutter for the first few seconds when opened
  • Added support for automatic updates
  • Due to the security improvement on this firmware, you will need to go through the factory reset process for your camera if you go back to firmware 4.36.9.139 or below.
Wyze Cam Pan v2:
Version: 4.49.11.4073
What’s New:
  • Due to the security improvement on this firmware, you will need to go through the factory reset process for your camera if you go back to firmware 4.49.1.47 or below.
Updating 3x v3 cams now.
All V3s updated without issues.
Did it from the firmware update page. Decided to do all at once to see. Worked great.
Edit
Just tested and my cameras load faster. Will see if it continues after a few days of use.
Just tested this issue:
Preliminary results are good. I updated at 3:11pm MT, went back and watched the SD card playback starting at 2:59pm and it continued playing without skipping the first minute of the hour.
Successful update 16 V3 cams w\ single button bulk update. No issues. Will monitor.
5 V3’s updated via bulk update without issue.
Having issues streaming to my Google Nest Home Hub after updating my three v3’s and pan v2.
Manually downgraded and the streaming is working again.
Pan v2 - 4.49.3.4054 (March 22, 2023)
Cam v3 - 4.36.10.4054 (March 22, 2023)
Sorry for the trouble. Could you help us by submitting a log for the streaming issue to Google Nest Home hub? We will check this issue. Thank you very much.
Log submitted. Log ID - 978643
Updated all 8 v3’s on the bulk update page in app. all went good. will report back if I see anything not working correctly
Just updated 2 x V3 cameras - 1 is ok the other will not connect to my local network. Tried reinstalling all goes well until it tries to connect to local network which fails.
How can i go back to previous fw version ?
100% update successful across all my v3’s without any manual restart/reconfig required. That’s a win for sure given my luck :smiley: and past experiences…
Welcome to the Wyze User Community Forum @bpagniello! :man_raising_hand:
You can download the previous version firmware from the Release Notes & Firmware Page, do a factory reset, unplug the cam, and flash the previous version firmware manually. I would do a factory reset after the old firmware is flashed successfully as well. The Firmware Page states that a factory reset is required if you go back, but it doesn’t say if this is required before the flash or after.
https://support.wyze.com/hc/en-us/articles/360024852172-Release-Notes-Firmware
https://support.wyze.com/hc/en-us/articles/360031490871-How-to-flash-your-Wyze-Cam-firmware-manually
https://support.wyze.com/hc/en-us/articles/360031484511-How-to-factory-reset-your-Wyze-Cam-v1-v2-v3-or-Pan-v1-v2
Manualy downgraded firmware to 4.36.10.3406. V3 cam working fine now.
Tried upgrading to new beta fw - update seems successful but camera will not connect to my local network !.
Manualy downgraded firmware to 4.36.10.3406. V3 again and cam is working fine now.
I guess I will wait for next update.
Have a v3 w/ flood light that is not responsive after attempted update. Tried power cycle several times. No effect. Any help on how to recover would be appreciated.
Updated 8 v3 cams using the bulk updater. Worked great! All cams updated.
I can confirm this is fixed!
I lost streaming ability using alexa skills to my amazon echo show 5. The alexa app also does not work with streaming after the update. I submitted a log (log id 982238). The stream initializes, but just hangs and then Alexa says “hmm the camera isn’t responding”.
