Wyze App 2.24 Beta Test (Android); Wyze Cam v3 Beta Test 8/23/2021
Wyze App 2.24 (Android only):
App Version:
  • 2.24.14
What’s New:
  • AI control settings have been moved to the Event Recording page under Device Settings for consistency and easy access
Wyze Cam v3:
(This update is only supported by Wyze app 2.22 and above versions)
Firmware Version:
  • 4.36.5.58
What’s New:
  • Improved an issue that caused Cam Plus Events to skip or lose frames
  • Improved camera stability
  • Security improvements
Android App Version Beta: 2.24.14
v3 FW Version: 4.36.5.58
  • I like how you can set AI preferences from within the Device itself under Event Recording. Makes more sense to me. :slight_smile:
  • “Security updates” for V3 was mentioned. Can we get what these security updates were so that testing can be done, if possible.
  • Went into Device Info on all V3 camera’s and there is “Firmware Version” lines. Only one of them you can click on.
Would like the CamPlus Device List to show which devices are on CamPlus first and not at the bottom of the available licenses.
Android View
Screenshot_20210823-190100
iOS View
Just updated my v3s and it looks like zooming in is broken. When I zoom, it stretches the image.
Here’s a link to a screen recording. It’s happening on my Android app, not sure if updating the v3 or the app caused the issue. Only happening on v3.
Just tried this myself and I can replicate it. Good find.
However, on my device it only happens in Portrait mode and not Landscape.
Can you confirm that if you are in landscape mode and double tap on the screen that you also don’t have the issue?
Trying to narrow down where the problem is for Wyze and the developers
Confirmed this is only happening in portrait mode
@Yichen
There is an issue with the V3 on the Android app when in Portrait mode. The image is stretched and not Zoomed when you double tap on the Live Stream. However, in Landscape mode, it is ok.
What it looks like on Android
Normal Portrait
Double Tap in the Stream
Screenshot_20210823-204103
What it looks like in iOS
Normal Portrait
Double Tap in the Live Stream
AI notification preferences aren’t available via device, event recording. I haven’t even able to find them since updating to 2.24 which is annoying because all the car notifications are constant.
there is a new update 2.24.14. It has been corrected in this release, 2.24.13 is where it is broken.
Screenshot_20210823-204937
Honestly right after posting that I go to the play store for my update check and see that wyze was one that needed an update, and I hadn’t looked as closely as I thought at the firmware version as I thought because I was on 2.24.13 and didn’t notice there was a new release, sorry for noticing that lol
Its not a big deal, I do that as well. Its all good.
Actually now that I’ve gotten to the preferences and removed the vehicle preferences from the two cameras that I didn’t want constant notifications from like I’ve gotten for the past week or so they no longer say vehicle in the event view which I would still like if I’m ever in need of the option to only show vehicles when looking though, so my thing is I don’t want the notifications but would like the option to keep them specific in events, has this been removed???
Thanks for fixing this so quick. I like the change in how you moved the AI detection stuff. And the variation of Night Vision IR on the camera. Helps with bugs! The physical kind!
@Yichen - could you please start putting the full app version in the title?
/edit - for example - “2.24.14”
and would it be possible to specifically state what and how we should test?
For example - “improved camera stability” - how do I test for that?
Updated app on my A20 - fine
updated “test” V3 - stated done, would not reboot past step 3. Tried turning off an on via app. Finally had to physically power cycle and it came up for view.
This is not acceptable. I’ve many V3’s hundreds of miles away that I cannot power cycle unless the power goes out.
Please do not ever apply a Beta firmware update to a remote camera! :scream:
I agree and would like to see this as well. The ability to select each type of AI event to record separated from the ability to select each type of AI event to get notifications for would be great.
Sneak up on and wiggle it? :wink:
Updated my 2 v3 yesterday (4.36.5.58) and they are rebooting by themselves each 30-60 minutes. I have just formatted the cards to see if this issue will be solved.
