V3 and PAN Review
Info taken from Amazon. Updated today with details.
For info regarding cables for the PAN - see the link below.
Link removed due to limit.
Review is on 2023-03-12.
Having owned the Wyze Cam V3 as my introduction to the brand - moving to the Pan V3 was almost a natural path. It’s a great camera for a great price. The bulk of the company’s money seems to be made on the subscription side, so the hardware price is sold with minimal markup it seems.
The camera itself - hardware and quality - are not much different from the regular V3. Good picture quality and such. There are 3 primary differences between the Pan and the regular V3.
1 - Panning capability. The camera can turn - not 360 - but almost.
2 - Not magnetic. Must be mounted on the provided base - or similar item that the screw can fit.
3 - Micro USB cable is right angle and not straight.
PANNING
The camera can turn almost in 360 degrees on the base. It has what’s called “waypoints” where 4 areas can be set and the camera will automatically move to each area once selected within the app.
The camera supports time-lapse and motion following.
NOT MAGNETIC
If you wanted something similar to the regular V3 that you could stick somewhere - this won’t do. Based on viewing the Pan V2 - they are similar in terms of the base. This does make some sense since the base can swivel, but it’s something worth noting.
USB CABLE
The regular V3 has lots of cables available that are weatherproof. Finding one for the Pan V3 - and I guess the V2 as well - is very tedious. The right-angle cable needs to sit inside the base of the camera and I’ve not found any extensions that have this feature. If you’re going to purchase a third-party cable, you need to ensure that the micro USB end is about 19mm/0.75in so that it will fit snugly inside the base of the camera. This means you MUST use the original cable. I’ve not seen a similar right-angle cable on Amazon or even on the Wyze website - so there’s no replacement. Another option - which I’ve done - is to buy an extension cable that is compatible with the device. I had a regular USB2.0 extension cable and it didn’t work - guess it doesn’t carry the voltage as well. Waiting on the linked device to arrive and test.
I assume I’ll either have to heat-shrink or tape the connection between the original cable and the extension. If someone else has seen the cable or something that will work - please link it within your review or as a reply to this one. The items below were found on the Wyze forums and linked here to make things easier.
CABLE
https://a.co/d/4ravLGo
TAPE
https://a.co/d/ceonpX3
Additionally - if you’re technically inclined - you could cut the cable and solder it to a different extension. Persons have said in the Wyze forums that it’s only power - no data - so just 2 wires are required. Do that at your own risk.
UPDATE - 2024-01-02
So now. Having had the device for some time, I’ve used and abused it a bit and have more details to add for the review. Both the V3 and the PAN has had some weird issues for me. I’ll get into those individually.
V3 - I recently decided to go on vacation and didn’t want my cat to be left without food. While my current solar setup isn’t 100% - it provides enough power until about 2AM and the area is secure enough that a dead gap isn’t a problem. I really just need the cameras to monitor my cat. So a typical “pspspspspsps” call to get the cat to come around is used along with the name - but strangely, the camera seems to cut out with errors once this is done. Almost like it dies - has some firmware issue - or something. I’m going to test and see if it’s the sound or pitch, but I’ve really not tested voice on any of the cameras for more than a few seconds previously. To get the attention of my cat I need like 1-2 minutes per camera. When the camera goes offline, it needs to be manually power cycled in order to be available again. Since my solar setup dies and comes back, that works out for the V3 somewhat, but it’s concerning that the cameras have a flaw where extended voice or a sound/pitch will cause them to suddenly go offline. You may need to test this with your own cameras to verify.
PAN - the V3 PAN has an even stranger issue. While it seems to share the same issue as above, it also seems to factory reset the device if there’s the audio function usage or even periodic power cuts - which happens based on the solar setup I’ve got going as explained above. Again, this is concerning. I have to climb up on a ladder to physically reset the device and rescan the QR code to have the camera available again. This is very inconvenient.
With those problems in mind, I think WYZE should have an option to “re-add” a camera that’s giving issues. That way any existing configurations including waypoints can be kept and you don’t have to do everything over from scratch - including sharing the camera with family members if you do that.
Again - hopefully this review helps and persons can be aware of potential flaws. Overall - still a great camera and the functions of the PAN are good.
They do. Do NOT delete the camera from your account. Simply add it again (same as initial setup). The system will realize that the camera already exist and all the settings will be right back where they were before.
Wow… Learn something new every day… “I did not know that”…
But, I’ve never had to re-add a camera… thank you for the info!
Did not try this previously. Will do when I get back home. Good info. Thanks for that.
Still trying to figure the whole cameras needing to reset after audio use. But again, when I get back.
That’s not a flaw with the cameras, it’s a flaw with your installation. because you are using a an excessively long 3rd party 32’ cable that isn’t supplying enough power, so when you make the camera do something that uses more power (using the speaker), it’s crashing. If you keep using that cord then you need to compensate with a power adapter that will push more power through the long cord (don’t send too much or you’ll have other issues) OR use the original cord and power supply (or the official Wyze Outdoor Power Adapter) and just use a normal Extension cord to make everything longer. You can’t use a 32’ USB extension cable without losing too much power, especially without sending WAY more power through cable.
Same problem.
These are COMMON issues that occur when people use long third party cords or 3rd party adapters. Using the microphone and speaker use way more power and when there isn’t enough power, the camera will pull it from critical things and crash the whole device. If you don’t fix this, you will continue to notice other frustrating things, including having events that don’t upload/play sometimes and many other malfunctions that aren’t due to a poorly built product, or bugs or anything like that. They are all COMMON issues that happen when people use long third party cords.
Personally, I’d recommend fixing and revising your review. The above issues are not Wyze’s fault in this case.
The following awesome thread by @Newshound may be helpful to you in resolving the situation:
Thanks for the reply. Would agree if I didn’t also have the issues when using the stock cables only without third party extensions. I’ll have to test this with the PAN as I’ve only tested the stock cables with the V3 only. Will test on another PAN I have since the installed one will require a ladder. If I see any difference with the stock cables only on the PAN I’ll let you know, but I do have the same issue with the V3 and stock cable only. I’ve also swapped out the V3 with a new one to test, updated firmware and still have the same issue.
Will do further testing when I’m physically there again and update, but thanks for the suggestions and insight.
You mentioned using some kind of solar installation solution for both of them too, so your problem could be related to your power source since you’re implying they’re off-grid. If you are using stock parts, but sub-optimal power source the problem will still be with the power.
I guess the main point is that the issues you are experiencing are VERY common with people who have low power issues getting to the cameras. People who have sufficient stable power rarely have this issue. For example, I have more than 40 Wyze cameras (and some from other brands), multiples of almost every model. I experienced some of these issues in the past, determined it was due to bad power, fixed that and I then never experience this issue, so I am speaking from personal experience that this only happens when the power source is insufficient in one way or another, and when that is resolved these models work fine without that problem. The issue could be the cord (length or quality), or the adapter, or the power source (instable solar setup you have), or something else, but it’s almost definitely something to do with the power. I’m just suggesting checking those out first so you can have a better experience.
I love hearing people who do solar solutions though! Especially for wired cameras like this! How big is your panel? Are you using a battery, and if so, what kind? I have long wanted to do a solar implementation myself. I have saved links from several other people who put up some walkthroughs on it. Maybe I’ll get around to it some day.
Thanks for the reply. Will DM you on the solar to keep the other things on track regarding the cameras.
Once you review the DM you might agree that the solar source isn’t the issue. I’m confused about the cables though, but from a technical and practical standpoint - I agree with you. I’ll look into it when I get back.
You are correct, I now agree the solar source is not the issue. Also, it sounds great!
The rest of my response is in the DM. I hope to hear back that you found something to help with the problem!
Not to stray too far off subject, but, why are you trying to convince your cat that it is going insane/hallucinating/being teased in some sort of “hide and seek” game with your disembodied “pspspspspspspsps”?
Can’t you find a battery powered feeder that makes some noise, instead?
I think you owe that feline a new toy, or something!
How about starting a new thread in Tips & Tricks about your Solar Setup? I’m sure it would be appreciated by many users who are looking for a off-grid solution.
Totally true and 100% correct. I’ve had the same issue with a 32ft cable and once I found a way to bring power closer to the camera all was fine.
