Repeat twice
how do i get v3 cameras from repeating notifications twice
Do you have Cam Plus and have it set to notify you for both Motion and AI detections? Or is it the exact same notification (ie: Motion twice)?
If you’re getting actual duplicates, I’ve seen this bug get reported by a couple of other people, though the one I was thinking of in particular had iOS. You are seeing this on Android? Assuming that is the case, then there might be an app bug that Wyze will have to resolve with an app update.
Are you getting two notifications or just two sounds? The two sounds thing has been a bug for a long time, i’m used to it. But there is only one notification attached to it.
The only place I’ve ever repeatedly (annoyingly) seen two notifications per event is on the Watch. In my experience, that issue generates two separate notifications that aren’t true duplicates (not identical in content), even though they’re presumably triggered by the same single event.
More detail about what you’re experiencing (like answers to the follow-up questions posed by others) would be helpful.
Welcome to the Forum, @resuttles! :wave:
That’s what I am getting as well. It drove me nuts at first but as you said, I’m used to it now.
After reading your comment in the recent iOS hotfix topic and playing around some with MacroDroid triggering on notifications, I’m beginning to think this is the case, because what appears to be a single notification in the drawer actually seems to trigger a macro twice, because the audio I’ve designated starts to play and then almost immediately starts again, so it acts like it’s being triggered a second time.
Very nice catch! Are there actual duplicate notifications in the notification shade or does it appear that the second one replaces the first one so it only does a double pop-up but not show twice in the pulldown shade where notifications sit until cleared?
Good question. When I experience the audio being triggered twice, there’s still only one notification in the pull-down drawer, and I haven’t tried watching what happens by intentionally triggering an event and observing the app’s/phone’s response in real time. It feels like a replacement. I don’t know about a “pop-up”, because I have the Pop on screen option for the WyzeMessage notification category disabled. :man_shrugging:
I’ve never seen dual popups and have been looking at the screen when the sound comes through. Sometimes the sound plays 2 times completely, sometimes a half a time followed by a a full one, other times just once.
No duplicate events anywhere in the app.
Yeah, I’ve never seen duplicate events in the app history/timeline, either, but the doubled up sound (or at least the beginning of a sound followed by the same thing restarting a moment later) does make me suspicious of duplicate notifications.
It is possible but if I look at notification history in my android, there is only one, and I’ve seen it pop up on screen when the dual sound happens and there is no sign that two came through (even if the second replaced the first).
