Except that internet outages don’t affect every ISP at the same time, and people are no longer limited to a single ISP who owns a monopoly like in past decades. Nowadays there is no easy way for a malefactor to know which ISP a house is using.
Just using my house for example, I have the following options:
- Comcast/Xfinity
- CenturyLink
- Utopia Fiber
- T-Mobile 5G Home Hotspot
- Verizon Wireless 5G Home Hotspot
- Starlink
- Viasat
- Hughesnet
- FWA’s (Fixed Wireless Access, such as through AT&T, Rise Broadband, etc)
- WiMax providers
Tons more. And even with Fiber, I may have a ton of different ISP’s managing the fiber. There are 16 different Residential and 25 business ISP’s allowed to use the Fiber in my area. So they would have to know WHICH of those ISP’s I use unless the whole fiber line is dead, then they’d have to know I use Fiber instead of one of the competitor options, and hope I don’t have a failover dual WAN going on like lots of people do nowadays (you can even get a second WAN failover using LTE for nearly for free if you use less than a few GB per month on it and only use it for emergencies when the primary goes out (there are ways to set this up).
I think a burglar would be crazy to think they are in the clear just because one ISP has an internet outage. That may have worked more than a decade ago when there were only 2 realistic options (DSL or Cable monopolies), but within the last few years, there is now a ton of competition and it’s hard to know what someone has.
Still, Local control should be implemented anyway. I want my automations to be reliable and continue running, such as my lighting automations. I also want everything to run FAST without a huge delay. I am all about local control, especially the more I am getting into Home Assistant. With Home Assistant, I can control my Wyze lighting REALLY FAST because it connects locally, whereas if I do Wyze app Rules, there is a delay since those go through the cloud. So now I have moved most of my Wyze automations to go through Home Assistant because it’s faster and more reliable.
So don’t get me wrong, I’m all about Local control, but I don’t think an intruder would be all that smart to think they can take advantage of an internet outage because there would be WAY too many risks that it’s a different ISP, or what the failover options are, especially since my sirens, etc will still trigger without internet (HMS audible alarms aren’t dependent on the internet), and my cameras will still record to an SD card, and it’s also possible to have Wyze cameras stream to an NAS storage using an RTSP converter like Docker Wyze Bridge, or many others.
An intruder would be dumb to assume they’re in the clear even if they knew which ISP I used and were confident it was down…
But Local control has it’s own value even without intruders being in the mix. I will never stop pushing Wyze to consider and improve local control options. I think for now they are mostly waiting to make such decisions until after the Matter Camera libraries launch. After that happens they will decide how to move forward and if Matter compliance and local control for cameras is worth doing. I think we’re mostly waiting on that.
