From Ring to Wyze
I had Wyze cameras a long while back but when I wanted a doorbell, the Wyze one was ugly. With the new black one, it was much more attractive for my house so decided since it had SD recording, I can get out of my ring subscription and record everything. I had 5 ring cams including doorbell. I thought these new cams would work like my old OG and pan cam but man what a mess this is. My new setup is 2 ring battery pros, OG, Pan v2, Doorbell v2. Some of my pain points are:
  • each cam has different UI, also different cool downs and recording lengths. Battery pro has 1 min cooldown but 12 seconds recording where the doorbell has 5 min cooldown but continuous recording. And sure I can have continuous on the battery pro but for only few hours when not connected so its 12 seconds or nothing.
  • the constant cam plus pop ups in the app are super annoying, I get it, you want recurring revenue but popping that up at every turn is so annoying. Why make SD recording, then purposely make it crappy and at every turn put cam plus in peoples face. Im sure this has been covered to death on here.
  • the Ring UI for events and the way it takes stills is infinitely better than Wyze UI.
  • Doorbell chime integration, I dont have existing so had to do the hack with a Wyze plug to manage a doorbell playlist (one song that is sound of doorbell) on my google homes. Its not ideal and wish they made a chime for this thing but at least now it rings all over my house.
There is some good things, mainly continuous recording and the quality of the new cams. The Wyze doorbell v2 is far better than the Ring Wired I had, at night it is full color with my porch light on so certainly an upgrade. I decided to replace the OG and pan with the new v4 to get upgraded quality but those wont be here for couple days. What different limitations will these have? Only time will tell.
My wishlist would be just allow people cool downs as ā€˜noneā€™ without the plan and also customize the battery pro recording length to say ā€˜while motionā€™ or at least 1 minute. Paying a $20 CAD subscription per month for those two settings is ridiculous. I dont care for cloud recording.
Iā€™m doing that, as well, but I use it to do a voice announcement (a Google Home ā€œbroadcastā€) and also automatically stream the doorbell video for one minute on a Google Home Hub, a Chromecast, and a Google TV. Itā€™d be cool if the hacks werenā€™t necessary, but they seem to work well enough for now.
You mentioned that you have a Cam OG, and that can be used as a chime for the Video Doorbell v2. I enabled that for a Cam OG and 2 Cam Pan v3s, and it works reasonably well, with just a few seconds of lag (in my experience). When Iā€™ve disabled it on my Cam Pan v3s (i.e., deselected them from ā€œCameras as Chimeā€), at least one of my Cam Pan v3s continues to ring with a doorbell press, though. Iā€™m not sure whatā€™s going on there.
Even if the Cam OG isnā€™t in a location where you would choose to place a chime now, since you said youā€™re replacing it with a Cam v4 you could certainly repurpose your Cam OG somewhere you actually want to be able to hear a doorbell chime.
Yeah my OG cam is not in the best spot to use as chime, most of my cams are outdoor or garage but thanks for the suggetion. Yeah I was thinking about the broadcast but I like the sound effect I found which is a playlist of 1 which makes a nice doorbell sound across 4 google home devices. Its about 8 seconds behind a doorbell press so not sure if the playlist adds latency vs broadcast. Wish google had a ā€˜make doorbell soundā€™ lol.
These battery ā€˜prosā€™ seem pretty amateur tbh. Quality isnā€™t that great and features without subscription somewhat suck. I am thinking of returning them.
I didnā€™t know (obviously), which is why I mentioned that you can repurpose it as a chime only (i.e., move it someplace where you want an accessory doorbell chime even if you donā€™t need a camera there) since you said youā€™re replacing it with a Cam v4.
Iā€™m not aware of any way to control the volume on Cam OG when itā€™s used as a chime, but the Cam Pan v3 has a slider for volume control when itā€™s enabled as a chime for the Video Doorbell v2. (I know you didnā€™t mention having a Cam Pan v3; Iā€™m just tossing that out there in case you have a location in the future where you might want a camera and a chime.)
Thatā€™s a cool idea, too. I dig it.
I donā€™t know what the difference might be, because Iā€™ve never tried that, but the lag with a broadcast can be pretty significant:
They doā€¦sort of. As part of your Google Home automation, you could do this:
  1. Tap Add action.
  2. Tap Try adding your own.
  3. Type (without quotes): ā€œWhat does a doorbell sound like?ā€
  4. Tap Done.
The resultā€”and you can just ask one of your Google Home devices this with your own voiceā€”is that Google Assistant says, ā€œThis is a doorbell.ā€ Then it plays a doorbell sound. Itā€™s kind of clunky, and if you build it in the Google Home app, the Configuration section (near the bottom, when youā€™re creating/editing the automation/routine) wants you to choose where to play the sound, but it lets you select only one device. I guess you could create a separate routine for each of your Google Home devices where you want that sound to playā€¦or you could just stick with what youā€™re already doing. :man_shrugging:
I canā€™t speak to any experience with the battery cameras. I appreciate the concept, and they look slick in pictures and videos, but I donā€™t really have a use case for something like that, so all of my cameras have constant power.
Yeah maybe I will try to repurpose the OG as a chime once I do v4s. I could ask Google to fart, my kids would like that although it does the ā€˜This is a fartā€™ first lol.
Cheers
Yeah, same thing. Iā€™ve done that, and I donā€™t even have kids! These also give interesting results:
  • ā€œHey, Google, who farted?ā€
  • ā€œHey, Google, pull my finger.ā€
Iā€™m so mature.
:roll_eyes:
One of the goofiest ones Iā€™ve encountered by accident is this: ā€œHey, Google, stop screaming.ā€ (I think it once heard ā€œstreamingā€ as ā€œscreamingā€ when I wanted the music to stop, but then it gave a weird response.)
Thatā€™s what Iā€™d do, especially since you already have it and, as you said earlier, you ā€œwish they made a chime forā€ the Video Doorbell v2.
I can see how this is confusing. Cooldowns = like this:
  • Non-subscription notification or cloud Cooldowns:
    • Battery Cameras with a PIR sensor as a trigger = selectable cooldown between 1 min to 5 minutes
    • All other wired cameras = 5 minute cooldown on notifications/short cloud events
  • SD Card recordings: Most cameras have no Cooldown on event recording to SD card. Can also record continuously.
They made the cooldown exception for battery cams to have a selectable cooldown, but I am not entirely sure why.
Cam Plus removes the enforced cooldown (unless there is an active bug like with the WCOā€™s right now).
Lots of us have been pushing them to make it all consistent. Strangely, there is a significant amount of opposition from the user base over which UI is better or worse. :man_shrugging: Some people refuse to use the newer cams solely because they hate the new UI, and some people want their older cameras to be updated to the new UI. I didnā€™t realize it was that controversial, but there are several heated posts each way. Still, I would bet that they will eventually move everything to the new UI because it offers more features overall.
Regardless, thanks for sharing your experience of the difference! These things are helpful feedback for Wyze employees who do peruse the forums from time to time to see what people are saying.
I once got picked for a 1-on-1 zoom interview with an employee for some kind of thing back in like 2021 or 2022. Iā€™d never heard of her at all, and didnā€™t know who she was at all, and the first thing this employee told me was that she was SUPER EXCITED to meet me finally. She had been seeing me and things I wrote all over the forums and she knew a bunch of stuff about me, but she had never even posted in the forums at all. I donā€™t think she even had an official forum account or anything, but she told me that she (and others) had often looked through the forums to see what users are saying and she and lots of other employees knew who I was, and this was even before some of my most famous posts that got shared with the whole company. So, rest assured that even if employees arenā€™t responding, I have had some confirm to me that there are many who will randomly browse around to get a feel for what people are thinking/saying so they can use that feedback. :slight_smile:
Thanks for all the replies. I really hope they open up some settings on these battery pro cams like cooldown and length, would go a long way to actually living up to pro name. I have a bit of time to decide before possibly returning.
