App event conversion to .mp4 causing audio on all saved/shared/downloaded videos to go out of sync/delayed
Something I’ve been noticing lately related to cam videos:
If I watch an Event in the Wyze App (whether it is saved to the cloud or on the SD card), the Audio is fairly well synced.
If I download the same event to my phone (whether from the cloud, or recorded from the SD card), or share it (ie: to Google Photos), whatever conversion process the Wyze app uses causes the audio to be out of sync and delayed by a second or more. Indicating there is some kind of bug in the app causing the audio to go out of sync from the original recording (which plays correctly inside the app).
For example, in several videos where I tell my toddler through the baby cam to go to sleep, in the app you hear me talk, then her lay down and go to sleep, but if I save the video, it often looks like she starts laying down to go to sleep before I have even started talking (which is not what happened).
I have noticed this on V2’s, V3’s and the VDB Pro…all are perfectly in-sync when viewed on the Wyze app, but the audio is delayed if any videos are actually saved). This indicates the bug is likely caused by the app during conversion to MP4.
I have noticed that the VDB v1 does not Provide images when being notified on iOS. On Android you do get the images. I had @R.Good verify this as well.
same, tried new hub, reinstall everything and every other possible fix. I can still can sleep through the alarm if im in the next room and the fan is on. The system armed is louder from the keypad than the hub itself.
The audio / video sync issue on downloaded file has been that way for years. My July 4th fireworks show video from 2018 shows this very well. By the end of the file, the sound from the last salutes comes several seconds before the video - and it should have been a second later.
Thank you @carverofchoice for posting the hub volume anomaly saga on the Fixit Friday Lazy Suzan (ie ‘rotating platforms’) and also posting back on the original topic for us all to click thru to this new unresolved issues popularity contest. I have added my hearts wherever I could… Although I think a more reflects my sentiment at the lack of progress to fix the problem. I would like for my siren to wake my neighbors. It won’t even wake me! Let’s go big or go home here.
Short version: Why am I unable to view a recorded playback directly from an event notification?
Detailed version: I get a notification of an event on my phone. I click on it to view and the app launches. I click on the event and see my 12 second clip. Then sometimes I want to see more and click “Playback” at the bottom but, I get a pop up that I don’t have a memory card installed. So I back out of events and go to the home page, click on the camera and then view the playback, in full through the history from the SD card. Why do I have to go through all of that when I already have a memory card installed AND it’s working as I can view the playback if I manually search for it?
Do you have a log to share? You may be in a unique position to show the cause of this issue. I haven’t personally noted it, so I can’t create one. Attempt the process, and when it fails submit the log, and share the number here. Thanks!
Try to access your SD card from Playback under both the live view and the Events tab. My thinking is the first will work, and the second will fail. Then go to the camera’s settings and go down to “Wyze Support”. From there select “Submit a Log”, summarize the issue, and submit. It will give you a log number. Post that log number here.
This will give them a chance to fix your issue even if it isn’t one of the top selections this week.
Web View is not currently working with Cam Plus Pro
This may not be a bug, and Webview is also only in Beta Testing, so perhaps this is technically more relevant to the beta threads than here. Also, I know Beta Testing was only supposed to be for “Cam Plus” specifically. It just seems logical that Cam Plus Pro would include all the perks of Cam Plus, and I’m trying to help add things I have seen mentioned in threads around the forum recently so there is good representation for the community.
@WyzeGwendolyn - Hi Gwen, Rick here from northern CO. I’m one of your very first customers, setting up three v1 cameras back on Jan 11, 2018. Since then, I’ve purchased a variety of Wyze products and recommended them to dozens of friends and family members. The initial request for app-wide Landscape mode for tablets (iPad in my case) came from me. This was probably before the forum Wishlist even existed. The verbiage in the wishlist item stating that the lack of Landscape mode causes difficulty for people with disabilities was a direct result of my initial request. This is because I DO have a physical disability that (still) makes it very difficult for me to continually rotate my iPad 90° (from Landscape to Portrait) every single time I use the app. Those with attached keyboards have their own reason(s) for wanting it, but I need Landscape because I simply cannot rotate my tablet as easily as others can. Given that my initial request was made FOUR years ago, would you please bring this up at your earliest opportunity to those within the Wyze management group who can make this happen? Feel free to use my personal situation (and this post) to illustrate the importance of this feature. After doing so, would you then kindly report back and let your customers who use tablets (and future customers) know what to expect and when? As I’ve stated previously, if the answer is that app-wide Landscape mode (for tablets) will NEVER be implemented, then please just tell us that. Thanks.
Android specific bug?
Media volume only works properly for Pan V1, doorbell, doorbell pro and WCO v1. Call volume shows up for v2, v3, and Pan v2. There’s a smaller range with call volume, You can’t adjust it down to zero and cant turn it on as loud as media volume. It should be fixed via an app update because the old Android app 2.15.21 used media volume.
Android 2.28.0 (102)
Video Doorbell specific bug
Doorbell image is shifted so high that part of image is covered by phone time/notifications/camera hole, etc (top line) in minimized mode. There’s a large black blank space below the image. Need to shift image down to occupy black blank space. If you compare the live view of the doorbell vs doorbell pro in the app you can see the doorbell pro image is properly centered and not shifted high with no blank space below it.
I still get in-app notifications even though they are turned off in my notifications settings. I have received notifications for flash sales in the past even with the setting turned off. Either the toggle doesn’t reflect the correct status or there’s no way to turn off push notifications for promotions.
Android specific bug for Bulbs
When I try to set a start time for wake up under sleep routines for my V1 and V2 bulb, it gets stuck on “loading” when I click on start time. You can’t even go back once it says “loading.” If you go to a different app and come back, it will let you change the time but the new time you pick will not save,
The only way to get the start time to save is to click on start time, wait with the"loading" message for about 30 seconds, then it will go back to the main sleep routines page. Then you can change the start time. It needs to immediately allow me to change the start time without needing to wait 30 seconds with the “loading” message screen on.
If you set a start time for bedtime, then it immediately lets you adjust the time without needing to wait 30 seconds on the loading screen.
In the events tab, filter to a group of cameras, then exit app. Then open the app and go back to events, the events page shows ALL CAMERA events, even though filter still says it is turned on only for that filtered group.
To show this is happening, if you click on your filters icon, and then click cancel, then wait a couple of seconds, it will show the green button with the number of cameras you have in your selected group. However, all of your events will still show up. You need to pull down to refresh and then only your selected group events will show up.
This only happens on Android and only for event filtering a group of cameras.
Hey Gwen, just a quick reminder that you actually chimed in the Sense Hub low volume thread and said that you guys were working on it. The problem is still ongoing, need your teams help!
This is an underrated bug! Thanks for posting. I have this problem big time too. I will even be wearing Wyze buds pro watching a movie, all audio coming through my WBPros and then view my baby Cam and suddenly all the volume switches to call volume and plays through the phone speaker instead of my ear buds and my babbling baby wakes up my wife, so I turn the volume to zero but it doesn’t go to zero. I sit there shocked that
I can’t turn down the volume all the way,
It’s phone call volume instead of Media volume
It’s not even playing though my ear buds despite them being paired to the phone even though media and phone calls both play through the ear buds, but the Wyze Cam volume doesn’t (at least not my V2 Baby Cam).
This one should definitely get corrected even if it isn’t chosen as one of the top 3 or whatever. I’m always scared to review events now at night or somewhere where I need it silent because sometimes events load with volume to start with, u can’t turn it to 0 volume and it plays even if you’re paired to eat buds. You can click to mute the volume in the app (not the phone volume), but this is definitely a recently introduced semi-critical bug IMO. Plus it’s not consistent with all the other cams, and consistency is important. I hope people consider voting for this one.
