Firmware Releases - Released 1/16/2024
Lots of firmware is coming out with security updates! Please update Wyze Cam v2, Wyze Cam Pan v1, Wyze Cam v3 Pro, Wyze Cam v3, and Wyze Cam Pan v2 soon. It will require the 2.48 app version due to the security changes.
:notebook:Read our Release Notes:
Tinycam pro stops working after updates. Got P2P failed to connect error messages. Have been using tcp with my android tv box to view 4 cams at a time. I can view only one cam using Wyze app due to app being in potrait mode. Have to scroll to view other cams in the group.
Anyone experiencing this? @alexey.vasilyev , any idea? Thanks.
Hi Catcat - I would remove the cams and then add one by one. That solution worked for me.
On which Camera model specifically are you having this issue (I’ll load the firmware and try to replicate)?
One of the best places to let Alexey know about this is probably here:
https://www.reddit.com/r/tinycam/
Thanks! tcp still works for you after latest firmware updates ? You fixed the problem by deleting and adding back cam ?
Thanks! The 4 cams streaming most of the time using tcp on my android tv box are V3s. I have 50+ cams installed, with quite a few cams not opened yet lol :smiley_cat:
Temperature is really cold down here in the deep south right now (I know you guys laugh about 25 F, but it is low for us). I had trouble getting the firmware to update on three of my old V2 cameras that had the Wyze Sensor bridge in them.
I had to end up bringing them inside close to the router for some reason, but they updated fine after that. I have updated a couple of V3 and V3 pro cameras successfully. I hesitate to update the last 6 V3/V3 Pros that are outside and up out of reach till it warms up some. Good Luck to everyone!
Hopefully the security updates are not ultra-important to wait a day or 2?
CatCat1386:
Is the cost of the Android version of TinyCamPro $4 for life, or a yearly fee?
The ONN Walmart Android TV box is now < $20, so I might want to rig up one of these type devices on my TV. Can you display more than 4 cameras on the screen at once? Do you just fire them up via the IP address of the Wyze Camera using standard Wyze firmware?
Thanks very much!
wyze v2- can still view my local cams but no longer able to view remote cameras using tinycam pro after todays update : (
Oopsie, what year…
I just checked. All of mine are streaming fine with Tiny Cam Pro on the new firmware. Try power cycling your cameras or something. If that doesn’t work, check and make sure they stream through the Wyze app still.
Make sure you have the newest TinyCam version. I know Wyze made some security updates with this firmware that required an updated Wyze app, so it stands to reason that Tiny Cam requires an update too. I don’t know what version Alexey might’ve added support for, but I am using Tiny Cam Pro version 17.0…5 and it’s working for me on that one. Which version do you have?
i am also using tinycam pro 17.0.5, all my home cameras are showing up great, but i have cameras at my father-in-laws house and at my mothers house. i can log into those accounts to view cameras using the Wyze app, but tinycam seems to be having viewing shared cameras
V3 firmware 4.36.11.8391 is working well for me. I don’t do anything complicated, just view Live Stream one camera at a time, view Cloud videos and view SD card playback. I updated each v3 one at a time. One interesting note is one v3 was showing 2 signal bars on 7095 is now showing 3 bars on 8391. This v3 is inside so there was no temperature change.
Thanks for pointing that out, I updated it.
one time payment. Bought long time ago.
Cams rebooted. Wyze app streams fine. But it can show 1 cam at a time only using my android tv box. tcp version same as yours.
Deleted all cams in a spare phone tcp, Just added 1 V3 cam, got 2FA sms and finished 2FA, Waited few minutes and got error :
P2P failed to connect (IOTC_ER_FAIL_SETUP_RELAY)
1st time saw this error IOTC_ER…
I would just email Alexey. His email is at the bottom of the tinyCam Support page here:
https://tinycammonitor.com/manual.html
Note: I didn’t just paste his email in here because Wyze generally likes us to avoid posting personal info type stuff, including emails in here. Also, I try to respect Alexey from having his email in places where more webcrawlers are going to snatch it up and spam him more often. So just go look on that link and email him. Let us know what you find out!
Thanks. I used that email address before.
