Extension usb/power cable
Will WYZE cam og and cam v3 worked with 25 ft usb power cable from Amazon ? Looks like WYZE only offers 12.5 ft power cable
It probably will, as long as you get a good high quality cable and power brick.
The camera will receive less power the longer the cable, and a cheap cable especially will degrade more and more
I have a V3 connected to a 25 foot USB A cable. The male end of the cable is plugged into the supplied V3 power adapter which is plugged into a smart switch. The provided USB cable is plugged into the female end of the 25 ft. cable. I don’t have an OG
I have three v3s connected with 40 ft USB cables like one below. None of them are powered with supplied power bricks. I am using 4.8 Amp power bricks shown below.
https://www.amazon.com/Extension-Compatible-NestCam-Charging-Security/dp/B083RBG2P2/ref=sr_1_2?crid=2FZFDI1W01DSK&keywords=Moyeel+2-+Pack+40FT+Flat+Power+Extension+Cable+Compatible+with+Wyze+Cam%2FWyze+Cam+Pan%2CYi+Camera%2CNestCam+Indoor%2CBlink+XT+Camera%2CUSB+to+Micro+USB+Charging+Cord+for+Home+Security+Camera&qid=1675026046&sprefix=moyeel+2-+pack+40ft+flat+power+extension+cable+compatible+with+wyze+cam%2Fwyze+cam+pan%2Cyi+camera%2Cnestcam+indoor%2Cblink+xt+camera%2Cusb+to+micro+usb+charging+cord+for+home+security+camera%2Caps%2C136&sr=8-2
https://www.amazon.com/Nekmit-Charger-Technology-Portable-Adapter/dp/B07MCWDKWV/ref=sr_1_3?crid=2YH1S1RWSGMIU&keywords=Nekmit%2B4.8A%2B24W%2BThin%2BFlat%2BDual%2BUSB%2BWall%2BCharger%2Bwith%2BSmart%2BIC%2BTechnology%2C%2BPortable%2BTravel%2BAdapter%2Bfor%2BiPad%2BPro%2C%2BiPhone%2B14%2F14%2BPro%2FPro%2BMax%2C%2BPixel%2C%2BGalaxy%2Band%2BMore&qid=1675026103&sprefix=nekmit%2B4.8a%2B24w%2Bthin%2Bflat%2Bdual%2Busb%2Bwall%2Bcharger%2Bwith%2Bsmart%2Bic%2Btechnology%2C%2Bportable%2Btravel%2Badapter%2Bfor%2Bipad%2Bpro%2C%2Biphone%2B14%2F14%2Bpro%2Fpro%2Bmax%2C%2Bpixel%2C%2Bgalaxy%2Band%2Bmore%2Caps%2C156&sr=8-3&th=1
Thanks for your reply. It looks like each usb wall charger will handle 2 cameras, right ?
Yes it will. On one of my cameras the siren cuts off sometimes as well as the two way radio. That one camera is the farthest from the router. The other two function fine.
You have the WYZE cam v3 cameras, right ? Do you have any WYZE cam OG ?
Only v3s
Hey there @IEatBeans! Do you happen to know what the maximum cable length is before there’s not enough voltage to power something like a Wyze Pan Cam v3?
Can you recommend any good cables?
Can you recommend any good power bricks?
It’s very hard to suggest individual items, because length of the cable as well as other factors are very important.
I definitely recommend you read this, theres a lot of useful info and links:
The Wyze 20ft extension cable is probably your best bet, and you may want to find a higher voltage usb block as well (like the ones suggested on that link)
You can always go with active USB cable like below, mind the one that I’ve linked can’t be used as a charging cable. But there are plenty on Amazon that can.
https://www.amazon.ca/BlueRigger-Female-Active-Extension-Repeater/dp/B005LJKEXS/ref=sr_1_6?crid=23XQ8J9DGIK2B&keywords=active%2Busb%2Bextension%2Bcable&qid=1691404144&sprefix=active%2Busb%2Caps%2C92&sr=8-6&th=1
You already have the Nekmit and they’re as good as they come. All my cameras are outdoors and powered by those adapters. They fit nicely in a weatherproof outlet enclosure including a smart plug.
That’s a heck of a post but being somewhat data driven, I like it. Thanks for that!
Ahh Active USB cables! I know this exists for USB-C but wasn’t aware it did outside of that. Thank you!
