Add More features to Wyze Web View
With the release of Web View, there has been a growing list of features to add. We have consolidated them here.
Please click VOTE at the top to indicate your desire for the listed feature enhancement. You can reply to this topic with thoughts on which of these are most important to you, We understand that having these requests consolidated in a single Wishlist topic means that you can’t vote on them individually. That is why commenting about your favorites, use cases, and personal significance is important. Wyze will consider those comments in prioritizing implementation.
Requested Features:
  • Ability to refresh individual camera feed.
  • Ability to sort and move around cameras on page.
  • Ability to set cameras to auto-load and start without having to press on each thumbnail individually.
  • Ability to load camera groups using different url’s.
  • Ability to create camera groups re-use camera feeds in separate groups.
  • Ability to hide unplaying streams
  • Add the ability to zoom
  • Ability to delete cloud event videos
  • Ability to download cloud event videos
  • Ability to download timelapse videos
  • Support for Firefox browser
  • Support for all camera types (Doorbells, battery-powered cams, etc.)
  • Allow use with Cam Plus Lite Subscriptions
  • Dark Mode option
  • SD Card Playback
  • Add ability to filter events by date and time
  • Allow Fast forward and Rewind in events
  • Allow time to be displayed in 24 hour format or 12 hour format (AM/PM)
  • Match the AI filter options on the Events page to the options found in the App (barking, meowing, etc.)
  • Add the ability to manually control the time slider
  • Ability to enable/disable audio for events
  • Ability to view shared cameras
  • Ability to share with a guest for a select period of time
  • Add Feedback button to the page for comments and problem reporting.
  • Capability of moving camera views around on the screen.
  • Capability of resizing camera windows to fit the screen. Auto sizing feature would be most helpful. Have three cams. Two are side by side and the 3rd one is only halfway on the screen. 1st camera should be in the upper left corner of the screen.
  • Back arrow doesn’t work to exit from viewing an Event. Hopefully fast forward and speed selection will be possible like slowing videos down.
  • Capability to save videos to hard drive from both Events and SD card.
  • Capability of removing non-Cam Plus cameras from the screen.
  • Don’t require logon after a certain period of time, similar to the app.
  • Brighten up and enlarge the snapshots of the events
  • Allow for Landscape and Portrait view
  • Ability to remove or add Cameras
  • Allow for use of a VPN
  • Allow streaming of more than 5 at a time
  • Allow/Block access to cameras
Yes I know Web View is still in Beta but -
Automatically show live feed instead of having to click on the “play” button.
Capability of creating groups with overlapping cameras. Cams in one group cannot be added to a second group.
No way to exit from full screen mode. ESC doesn’t work and no “back” button.
SD card access would be helpful.
Needing to logon again after a certain period of time is annoying! The Wyze app doesn’t make us do this.
Agree with the last one. The timeout is very short and if you have two factor authentication takes a bit to get logged back in. At least give am option to trust the device to bypass 2 factor
@UserCustomerGwen
Web View - User Interface / UI Suggestions and Thoughts
So glad you have PC live view. This allows me to move off another platform and onto Wyze, and the image details is so much better . . . thanks. Would prefer that mobile login and PC login make use of the same authentication (Login/PW) as this is not the current setup. Would prefer that when I hit the back button from viewing events that I should not have to login again. Would prefer to also be able to use PC interface to denote live-zones for notifications. I think my license is assigned correctly to the (1) CAM I have as this was NOT the case until a firmware update SEEMS to have addressed the issue. Please have a team walkthrough login/pw for new accounts, license (subscription) assignments, as well as an overall review of the end user experience when navigating the application. Again SO happy you now have WEB/PC live view support! Thanks Much
Wyze Web View - download/delete videos (selected & all)
Now that the Web View is in beta, please add the ability to download the event videos. Thanks!
Wyze Web View - SD card playback
A playback option for the web view. It would make it so you could review footage on a bigger screen.
I hope somebody at Wyze is looking at this.
For me the beta is working OK (Chrome, Win10). But two nits:
1 - When I haven’t looked at the camera for a while (hours or days) I get the “Please log into your account” whenever I hit https://view.wyze.com/live
2 - Then I get a black window and need to hit the Play button in the middle to start the stream.
This seems like two completely needless steps that slow me (and presumably everyone) down.
Can’t you save a cookie identifying my PC and not ask me to login again every time? (All I want to see is my driveway - it’s not exactly top-secret info). It’s even worse with 2FA enabled (I turned that off).
I understand some customers may not want it that easily accessible - fine; make it optional.
And why not just start playing immediately without waiting for the Play button to be clicked? I don’t see any point in that - I can’t imagine why I wouldn’t want to see the live feed once I hit the page.
I use the Wyse cam to check my driveway (and will be adding a doorbell). It’s important to be able to get a live view quickly without a lot of needless delaying steps - I’d like to be able to just double-click the link on my desktop and have the video come up without me needing to do anything else.
More feedback on the Events View:
For me the dimmed snapshots of each event are too dim - I can’t tell if there’s anything I want to see in the event or not (without highlighting with the mouse).
I suggest instead don’t dim the snapshots, just change the color of the background to show which event is selected with the mouse.
See screenshot: Pasteboard - Uploaded Image
Also the snapshots are way too small.
100% agree on 2FA issue!
@UserCustomerGwen Please help us
Hey all WyzeGwendolyn is out of the office for a bit.
There is a few loose requests that fall in line of your enhancement requests in the wishlist thread, but best way for your enhancements/requests to be seen is here
https://forums.wyze.com/tags/c/wishlist/12/web-view
And to help any discussion be seen, it is best to post it in the announcement thread.
But yes, Gwen will be out for a few weeks.
Let’s try to call for @WyzeJasonJ instead then :smiley:
@fbb078a3c3441d08eb1e
You called? I have read through the conversation an d Web View is currently in beta so they are continually working on it. The 2FA and timeout issues have been brought up to the team.
Agreed. I would love to see it able to mark multiple videos for download to my computer… not just the phone or tablet. My other security cameras have this feature and it helps so much.
I wish I could control the field of view. I would like a narrower view.
I am now able to download event videos directly to my computer, but only those triggered by Sound events. Why is the same capability not available for Motion triggered events?
Welcome to the Wyze community knowHow. Web VIew is in early beta testing. As a beta product, Web View is a work in progress… i.e., it’s not a finished product.
Web View - Support Wyze Cam Outdoor with Solar Panel
Please consider the allowance of viewing the Wyze Cam Outdoor on the Browser Web View IF the Camera is attached to a Wyze Solar Panel.
