Wyze Watch Makes Its Debut! - 12/1/20
Alright, the page should be good to go if you refresh. :slight_smile:
Yay! It’s back. Thanks @UserCustomerGwen!
I could see the utility of running a how to video on the watch, but I can’t say I’d be in the market to listen to music on a watch or actually use it as a phone. Control music, accept calls etc, definitely, but actually listen, seems like so many options for a better experience. I guess that’s why I’ve never really found smart watches too compelling.
Hi @UserCustomerGwen , I am not sure if this is right but in the specs it says the 47mm is 300 mah and the 44mm is 260 mah battery capacity, but on the diagram on the main page, it is flipped.
Am I reading the specs wrong? The smaller one has a faster CPU?
Will I be able to configure the Oxygen sensor to run at regular intervals? This is helpful for Covid-19, and there should be an alarm if the O2 levels dip dangerously low!
I do not see anything on it, so I assume I cannot control music on BT enabled device or even my phone using this watch?
@joshridl, I don’t know the depth from the surface of the watch face to the back of the watch yet but I asked the team for it.
@awankier, I’ll ask the team to whip up a comparison chart later! :slight_smile:
@carverofchoice, the passive measurements are static and you cannot adjust them. You can prompt a manual reading for heart rate every five minutes. There is no subscription and these decisions were made for battery life.
@sskaggs, you can use Wyze Shortcuts with the Wyze Watch but you are not able to unlock Wyze Lock using it at this time.
@vaasish, the OS is RTOS but it does not have NFC.
@Senthil, you can pair Wyze Watch with iPhones!
@vaaish, both have bezels on top, bottom, and both sides. The battery life is similar on the smaller model.
@hoffdad, we’re sorry to hear that this product did not meet your needs. I’ll share this feedback with the team. You may want to check out Wyze Band on our website. :slight_smile:
@tnradio, 22mm bands are compatible. Glad you have a source for that!
@muerte33, it does not do blood pressure or body temperature but I’ll share your interest in those with the team! It does have vibration. :smiley:
@timothynott, I’ll share this feedback with the team. We apologize for this not being the product you were hoping for!
@Illumination, I’ll report this to the team!
@scotthanks, that is correct. There are slight hardware differences between the sizes.
@43r5789y23489, you will have to manually prompt it and there’s a 5 or 10 minute cooldown. It does not do a passive oxygen reading for battery purposes.
@th3naman, music control is in testing. The music won’t play on the watch itself, though.
easy opt in software fix
Howdy @UserCustomerGwen ! I see you mention 22mm bands above will fit. Does that mean that a 22mm standard watch band will fit this watch? Not just the offerings from Wyze correct?
Thanks, tried the band but missing a speaker for audible Alexa responses as well. Wish we could provide input prior to the design phase, to provide input on what we’d like to see in your products and what we’d be willing to pay to have those features…
I would also like to see regular heart rate measurements enabled, with an easy software update. It should be an option for those who want regular measurements, graphs, and alarms.
@UserCustomerGwen I guess I should clarify then :slight_smile:
So this image and some of the fames in the video seem to indicate the 47mm case has the screen nearly the full size of the front plate but the 44 on the right seems like there’s much larger top and bottom bezels closer to how the screen works on the Band. I like the idea of the size of the 44 but I don’t want another situation like the band where the actual screen is just a small portion of the face.
Do you know what the actual size of the screen in relation to the face is for both sizes?
Any chance the watch will auto-sync health data (daily, hourly, whatever) with the app? Or will it also require manual syncs like the Band?
People are also going to want the watch heart rate data to be compatible with popular fitness tracking apps like Strava.
This strikes me a little funny. It wasn’t that long ago that a watch let you know what time it was. :wink:
@UserCustomerGwen any info on what eckmannmiles91 posted about the specs? Seems the smaller one has a little better internals?
@UserCustomerGwen Will this work with Strava, Rouvy, Zwift, or other fitness apps?
It would be nice to see a list of the"popular apps" that will work at launch. Hopefully, more than the promo page shows.
@UserCustomerGwen, the email I just got said the $20 is the ā€œpre-orderā€ price. Can you say what the regular price will be after the pre-order sale ends?
