Mine is not, no, but I don’t believe it’s related to the issues you specified, and I have an open ticket with Wyze which I anticipate they’ll close without directly addressing my questions.
I have a can plus and was checking my recent events and there isn’t any. I looked back like 4 days and nothing. Looked a little further back and noticed the events are recording but all of a sudden the last couple three days did not.
Can’t say.
I had similar problem as your. Sometimes it didn’t record events when I walked or car drove pass by the video doorbell. Some other times, events recorded when there is slight movement of a leaf or tree branch.
I exchanged the video doorbell (purchased through Amazon) and stay at firmware 4.51.1.8444 (January 24, 2024) ever since. Afraid to upgrade
. Read some people had their issues fixed with new firmware. Some didn’t.
Both vdb.v2’s are on 4.51.2.0578 using app ver. 3.0.5 (558) on Android. No problems and recording fine to cloud and sdcard.
Were you having the issue where it missed motion events?
Not that I was aware of, except when it mysteriously went offline and wasn’t noticed for awhile. Was always my back doorbell almost never the front doorbell. Didn’t matter even when I switched them. Improved with the automation for daily restart. Whole system really stabilized with 2.5 app version with no degradation with 3.0. I am on Xfinity but have my own gateway and 3 node 6e mesh.
Apparently, it requires a stepwise update. @sdoxsee & @Salor (and anyone else who’s been forgoing newer firmware), I finally updated last week because of an unrelated issue with my Video Doorbell v2, and since Wyze Support suggested a warranty replacement, I figured I didn’t have anything to lose by trying. I’m pleased to report that the update succeeded, and I still have fairly reliable (i.e., no worse than before) notifications with the latest production firmware, plus I now get to enjoy WDR, which provides a noticeable improvement with the daytime color images. ![]()
Having similar issue with wired doorbell mine stopped recording smart detection but only motion support was useless. I purchased a new wired doorbell and it worked well for a short time now is doing the same thing.
@kknauss2015 - Can you post some specifics. Android or IOS? App and db cam firmware versions? Detection setting? Using the chime resistor(s)? Transformer size? Person detection thru cam+ lite or pd subscription? ISP equipment or independently owned? If isp model of modem/gateway?
I ask all of this because my 2 vdb.v2’s are solid and working perfectly. I also have daily restart automation on both
If you are having issues with the VDBv2, consider reporting them in the following thread:
