Wyze Switches
Any schedules set? In the individual switch device page of the ones that turn off at 10p, go to settings, then “schedule”. Anything set?
FYI, I have gone ahead and deleted all the switches and the group.
Following that I reinstalled all three switches and added ON and OFF rules for each switch. We’ll see how that works tomorrow morning or later tonight……Thanks again for hanging in there with me.
Kind of late to the party here, but offering my 2 cents.
I had a similar problem with Wyze Lights not going off on a set schedule. I wanted the lights to turn off at 10:00pm, and they never would. One of the forum members said to modify the rule to not go off at the top of the hour, adjust it by 5 minutes or so either on either side. That fixed my issue. I’d suggest having your switches to go off at 10:25 (or some other non-zero-ending time) and see if that fixes the problem.
KimKorner, Thanks. I’ll give tat a shot if my uninstsll/reinstall fails…tlhutch4
I am very pleased to announce that after numerous attempts to get my Wyze switches (3) to turn off as per the rule ( ON at 10 min before sunset and OFF at 10:30pm) is now working correctly.
After all the many suggestions to fix this issue to no avail I decided to delete each of the switches from my app and do a clean reinstall. Following that I set up new rules for each device according to the above schedule and it is finally working correctly. I’ll post the rule for one of the devices next. Each device has the same rule but listed separately.
Thanks Again to everyone who was trying to get this problem resolved for me.
