Wyze Solar Panel Mounting
Does anyone know if the outdoor solar panel comes with a magnetic option for mounting? I am hoping to hang it that way so I don’t need to drill holes into a metal storage container that I have.
Unfortunately, it does not. However, I mounted one on my gutter using nylon zip ties
@bryan.arnado,
I installed a Wyze Solar panel a couple of years ago. I do not remember a magnetic option. The feature set for the panel on the wyze site lists only the screwed in, movable mounting. The panel has to stand up to severe weather “wind” and would not hold.
I am in the process of mounting a 4 panel array (not Wyze). I have been eyeballing weatherproof Velcro (from Velcro) that claims it can stand up to severe weather. They claim it can hold up to 15lbs.
I to am placing it on a shed roof and do not want to drill. If you go down this path the panel becomes semi-movable. Just make sure you adjust it for maximum sun exposure.
That’s not a bad idea. Here I was considering whether I wanted to buy some kind of gutter mount.
FYI… My Wyze Cam 3’s came with a removable magnetic attachment that can be used for mounting.
Thanks for sharing!
