This would be insanely helpful for us that use Wyze products at the home of elderly or disabled people in our lives.
Rules are fine, but their options can also get in the way on the various times you don’t need them. IE: your living room lights go to 5% at 8pm while sitting there with family and friends when they visit.
For older and disabled people manipulating or even remembering to use an app on their phone is not intrinsic or easy. Wait till you get old enough that your fingerprints are so wore down even ultrasonic readers cannot register them easily or be very successful if you can.
Unfortunately, we cannot all be five minutes away and even if we are, getting called at 4am because, “all my lights are doing weird things” is not fun and often times the result of the person trying to interact with that app and they do not have enough mental or physical agility to do so.
Everyone trusts the audio and tactile feedback of a physical button click, or switch. And it’s been programmed into everyone alive to use a light switch when entering or leaving a room. Same process.
The Wyze Action Button. Unbox it, hook it to the wifi and it then does nothing. You tell it what it does when pressed via Wyze rules that already exist (and hopefully are expanding more).
Press the button, the Wyze app fires off the Actions in your rule.
As noted, press the garage door button and the Wyze Action Button is a much simpler process and way more successful to reach the outcome of getting lights and things on for people with extra needs to see, feel secure, etc.
In the meantime, at least add a modern Android and iOS “soft” action button to run a rule set. A big well labeled button on a smart phone home screen would be a good start as well.
Wyze products are easy to use, but add loss of feelings in fingers, bad vision, tremor, any level of dementia or related, poor memory, or 100’s of other conditions, even when minor, just lowers the success rate of our loved ones in these scenarios to single digit percentages.
Just a simple, well made, button. Good solid mechanical click feeling and a good mechanical sound when pressed (not an audio recording through a tiny speaker). Add three color less, blue pairing, red error, green = button press achieved. The green light should also have a setting where it stays on until pressed again or just slowly dims away after 5 minutes.
