My Wyze Sense hub stopped working, showed offline in app. All sensors went offline as well. I tried to reset the sense hub, the middle light turned off then all 3 lights turned on as it was resetting but it does not make any sound to be ready to be added to app again. HELP!!!
I suspect you need to go through setup again now.
Follow these instructions in order:
How did you reset it. I had a similar issue and did the bring process which did not help.
Here is what you need to do:
Unplug the power and then press the button on the back for 10nseconds or a bit more. The moment the lights change or go out release the button and then plug the power back in.
I did just like that … no change … then I pressed the reset once it didn’t say “ready to connect” as expected …
Also I noticed it’s used to say “running on battery power when unplugging power” … now it says nothing … 3 lights seem to respond promptly when pressing the reset for 8 seconds but it no longer speaks anything ![]()
