Wyze Night Light Syncing/Linking Issue
Is anyone else having issues linking all lights? I bought 2 3-packs and so I have 6 lights. I can get 5 to link up, but not all 6. Is there any way to reset the link or start linking over?
If you turn them all to the off position (pairing resets), then turn them all back on to the Auto position they should sync up together. A re-sync if you will.
I place them all together on their side with the switch up so I can just flip the switches quickly. The lights will pulse then shut off once synced.
Info from the FAQ Page
What are the different modes?
On: The light will always be on.
Off: The light will be turned off and the paired network will be reset.
Auto: Light will automatically turn on and both the dusk-to-dawn sensor and motion sensors are on.
How do you setup link feature?
Group use: To pair Wyze Night Lights together, switch all devices to Auto. You can pair up to 10. In the first 30 seconds, the device enter pairing mode and blink. After 30 seconds, the night lights should be paired and blinking will stop.
Individual use: Switch the device to Auto and wait for 30 seconds to end pairing mode.
Also, make sure you test in a dark room. The lights will not necessarily light if they are in a lit room. Depends on how dark they think it is.
I have 6 and one wont sync up and I placed them all on a cookie tray together and turn them all on the same time to AUTO.
I currently have 8 night lights in 3 different groups. When I powered them off and charged them up, none of them would sync. I spent days on this issue, and the thing that fixed it for me was to leave them all on and fully discharge the battery. Once that was done, it allowed them to be synced. Even support had no idea this might fix it, so these products aren’t great.
Previous to the fix, I’d switch them to auto, and immediately get a 5 quick blink light indicating that they were paired. They weren’t, so I had to “clear the memory” by discharging them to zero.
Try quickly going Off, On, Off, Auto. If the light slow pulses On/Off for about 20-30 seconds before triple flash… that was likely “pairing mode”. If it triple flashes within about 3-5 seconds of going to Auto… that has likely skipped pairing mode.
