Wyze night lights stop linking?
I have six Wyze night lights I bought half a year ago. They still turn on manually and automatically just fine. However, it seems they gradually stopped being able to link. They could all link when I bought them, but now none of them can link.
I’ tried the following:
  1. Fully charged all lights.
  2. Toggled them off, on, then off again.
  3. Placed them next to one another, then set them all to Auto at once.
  4. They quickly flash 3 times in 1 second, then remain dark.
At this point the motion sensor for any individual light turns it on, but none of the other lights turn on at the same time. Basically, the linking feature seems dead in all the lights. How can I fix this?
Hi @thalassicus
I apologize for the issue and my delay in seeing this. I would recommend reaching out to support to see if they can help you.
https://support.wyze.com/hc/en-us
Hi. I’m having the same issue with a set of three brand new light (2022).
What is the solution please?
Tldr - Try quickly going Off, On, Off, Auto. If the light slow pulses On/Off for about 20-30 seconds before triple flash… that was likely “pairing mode”. If it triple flashes within about 3-5 seconds of going to Auto… that has likely skipped pairing mode.
Full Summary:
I haven’t given it enough time to 100% understand, but I gained a little understanding & got mine to re-pair.
I have 4 of the 2022s. I somehow lost all pairing & needed to set them back up again. At first, when going from “Off” to “Auto”, they would immediately triple flash within about about 3-5 seconds. In this scenario… they never paired. I think the triple flash means that it’s headed to Idle/Auto mode, rather than pairing mode.
While playing with it, I quickly swapped from Auto to Off to On to Off to On to Off to Auto… & noticed that it didn’t immediately triple flash. It slow pulsed for about 20-30 seconds & then triple flashed. When I did this with two of them at the same time… those two paired.
The next two, I believe I went quickly from Off to On to Off to Auto & it went into 20-30 seconds of pulsing, triple flashed, & they synced up.
In both of the cases where it worked… i may have also had them “off” for more than a few minutes before attempting… though I am not confident that was part of the fix. I think to forget existing pairing, you likely go quickly Off, On, Off, Auto.
