Wyze Lock Gateway lost connection and i cant reinstall
I need rather quick help. I have a remote location that uses the Wyze lock. This morning after about 5 years it lost connection. The Gateway lost connection. I have now been trying for 6 hours to get it connected before leaving in 2 days. It can find it but not connect. I removed it to reinstall but that didn’t help at all. When i plug it in i get a fast green flashing. then a slow red flashing. Then i hold the button for some seconds and it flashes red and then blue then red, etc. I try to install at that time. all is ok until it gets to pairing then it fails. I am using 2.4 not 5 on my phone when i do it. I’m not sure if there is another trick to this. Any ideas?
I don’t have the original Wyze Lock (so I don’t have Wyze Lock Gateway), but with some stubborn IoT devices I’ve had to do a few things in order to get them to connect or reconnect to Wi-Fi:
  1. Move the device closer to my Wi-Fi source (main router).
  2. Turn off all radios except 2.4 GHz SSID on main Wi-Fi source (i.e., disable radios on any range extenders and turn off 5 &/or 6 GHz bands on the main router).
  3. Turn off mobile data on the phone I’m using to attempt device setup.
I don’t know if that’s the kind of stuff you’re doing when you say this:
What I’m suggesting is temporarily disabling everything except 2.4 GHz Wi-Fi so that your phone is forced to use that for its Internet connection. Then, once the IoT device is (hopefully) connected to your Wi-Fi, you can re-enable your phone’s mobile data, your network’s 5 GHz radios, etc.
Like I said, I don’t have this particular product, but these are the kinds of things I’ve had to do in the past in order to get some smart devices connected to the LAN.
Thank you. In will try to disable 5 and just use 2.4
You’re welcome. I hope that helps. Just last night I was setting up several older Wyze devices (several Plugs, Plug Outdoor, Light Strips, and Light Strip Pro), and I took the precaution of disabling all of my 5 and 6 GHz Wi-Fi because of headaches I’ve had before when trying to connect some things like this. I didn’t have any significant problems getting things added that time. (I had a heck of a time re-adding a Wyze Plug over a year ago, and I think I learned lessons from that.)
If you’re able to reconnect your Lock Gateway, then you should be able to safely re-enable your 5 GHz band and also move the gateway back to its original location (if you move it closer to your Wi-Fi source for setup). Moving the device and disabling non-2.4 GHz Wi-Fi are just temporary measures to hopefully improve connection success.
Thank you. i was able to reconnect the Gateway and turned on my 5bhz again and all is well. thank you.
Oh, good! I’m glad that worked. Thank you for taking the time to post an update! :+1:
