Wyze color bulbs issue
Has anyone other than myself noticed that if you have more than one Wyze color bulb close to others, and have to replace one there is a prolem. New bulb color doesn’t completely match the older bulbs… Meaning you may have to buy multiple color bulbs if one goes bad to have them all match again.
New color bulbs are not producing the same color as older bulbs
@Seapup
Was your reply a question or response to my posting ?
The discussion in the linked topic addresses your question about anyone else noticing a color difference between bulb versions.
The issue to me here is a cost issue. It appears to me that if any of my four bulbs go bad I have to replace all four of them to keep the colors consistent because they are in close proximity. This is an unexpected and expensive situation.
Those of us who noticed the same feel the same. I can’t resolve it for you. As indicated in the other topic, we can only note it in the next Fix-it-Friday.
