Wyze Cam v3 & Pan v2 Firmware Beta Test 12/13/2022
Yep
I’ve even unenrolled CAM PLUS and reenrolled before, turned VEHICLE off/on, etc. I am in contact with SUPPORT about this though because when I received the camera, it was very suspicious as the camera was used. I purchased two v3P, one of them is working great with detections and is new (based on the activation date) and then this second one is problematic and has an unusual activation date of two months ago… I guess I’ll wait for their reply as well because it’s sketchy if someone else has activated this before me as I paid for a NEW product.
I see you are using an iOS Device. I have been troubleshooting some AI issues with Wyze related to iOS. It may be a similar situation as it is primariiy with the V3P. Can you get a log of it so I can pass it on to the individual I am working with and see if it is related.
thanks
I have original V2 with plus, used to be so reliable…now never know when it’s going to work correctly…or at all…Seems like Iam tweeking it over and over again…when it works it’s great, the next day? Why doesn’t it work…I don’t have time to do this every day, …test this, test that, restart, unplug…contact wyze, screen shot my settings…OMG…is anyone else getting worn out like Iam…I have my Swanns wired cameras that I rely on to fill in the gaps…thank goodness…
Yep, it’s iOS. I’m having issues with getting live stream SD or 2K working reliably. It works great of course at 360p… but when I had my v3 mounted in the EXACT same position, it did HD no prob… also when it was the v3, it was max wifi bars while V3P is only 2 bars - I would’ve thought the new hardware should’ve been an improvement – but I digress from the intent of this topic post. You can have the logfile #852848 provided you promise not to spy on me changing. :shushing_face: :rofl:
Do you use the BETA firmware though? I have some cameras where they’re absolutely mission-critical, so I avoid hitting those with BETA unless I feel super confident (or stupid, whichever you choose) and leave them as the last good-working stable. If you’re running BETA, you may be getting fun features not GA yet, but that also leaves you open to potential issues unless you want to use a SD card and back-flash.
Thanks @SlabSlayer. I’m a beta tester. I have a Cam Pan V2 that has red ring of death. I was hoping to flash this version manually to try and fix. Previous versions flashed manually don’t seem to fix it. Seems such a waste. If you know how to fix please let us know. :slight_smile:
Cheers
Yea, that is the issue. I know they are working on this as it is only happening on iOS and not all individuals are experiencing it. Seems it may have to do with the amoiunt of Data being processed and iOS.
I will pass this on as well.
Well… amount of data being processed and iOS is an agreeable issue then, haha, because very FEW of the captures (even though they successfully upload and recorded to SD) show a proper thumbnail.
Yea, you should see mine. When I filter for the V3Pro’s only, it is mostly the camera icon, sometimes there will be an image. But this may be related. I am working with them on:
  • Missing Thumbnails
  • Missing Image in notifications
  • Live Stream not always streaming in iOS
Wyze has said that they are aware of the issue and are working on getting it corrected. Trust me, they are working on it. This is wht the Logs are important.
I don’t know what that is. Can you elaborate? Might be something that is in another topic since this is the Beta reporting thread.
Cam V3 4.36.10.3406 - SD Playback skips first minute of the hour during playback.
Bug persists in this Beta
Sorry, will follow up in this topic. Wyze cam V3 stuck on solid red light - #53 by JeffB
I did a bulk update today. All camera’s work beside the camera that is connected to my garage controller. I tried to flash to previous version and that is not working either. Thoughts?
The V3 failed and went offline 3 times. Each time it needed to be disconnected from power to reboot. Left it for about an hour and it had finally updated.
Pan cam V2 with a code 90,after beta update. any fix?
Have 2 V3’s.
Bulk update failed twice.
Then powered down the cameras & after power back on bulk update was a success.
Updated two V3 to 4.36.10.3406 without issues, but there is No improvement in Jerky SD card playback.
Beta issues with SD card recording looks like visible video tearing and sometimes like the invisible man is walking around. Have reformatted all the SD cards and restarted the cams but didn’t fix the issue. Just wanted to know if anyone else is having this issue. SD cards are set to continuous recording.
Yes, same issue.
What’s strange is if you record the jerky broken up SD card playback the recording looks better.
I’m in the beta program and have selected V3s for testing. However, I just installed two new black V3s and they aren’t recognizing the beta firmware as available for installation. I’ve rebooted the cameras and de-selected and re-selected them in the beta configuration to no avail.
Any suggestions?
