Once you are signed up you can go into the Wyze App (Account>about>beta program) and select which devices you want to allow to receive beta firmware. After that you can install beta firmware from the device settings.
Hi,
You have to be a beta member, then it will be available through the app the same as normal updates, already performed.
If you are not on beta, follow instructions here
Kind Regards
G Thomas
