Wyze Cam v2, Wyze Cam Pan, Wyze Cam Outdoor v1 & v2 Firmware Beta Test 8/9/2022
Wyze Cam v2 Beta:
Version: 4.9.9.1355
What’s New:
  • Fixed a bug that caused Cam Plus Lite events to freeze and drop frames
  • Fixed a bug that caused Sound Events to be recorded when a sound recording is turned off
  • Other bug fixes
  • Security improvements
  • Due to the security improvement on this firmware, you will need to go through the setup process for your camera if you go back to firmware 4.9.8. 1002 or below
Wyze Cam Pan Beta:
Version: 4.10.9.1355
What’s New:
  • Other bug fixes
  • Due to the security improvement on this firmware, you will need to go through the setup process for your camera if you go back to firmware 4.10.8. 1002 or below
Wyze Cam Outdoor v1 Beta:
Version: 4.17.4.278
What’s New:
  • Fixed a bug that caused microSD card recording to fail when allowing time zones offset by half an hour
Wyze Cam Outdoor v2 Beta:
Version: 4.48.4.278
What’s New:
Just updated the WCO V2 and V2 cams. All updated without issues. Will monitor and test
PansV1 and Wyze cam V2. Same issue in the previous beta.
Issue when recording from Playback. The video saved in the album doesn’t play and there is a white screen in iOS album. (IOS15.6) Don’t have this issue when recording from Live view.
The updates went fine for my 8V2s and 3 PansV1.
Edit: the choppy events clips created with the last beta (x.x.1273 ) seems to be solved. Now they are correctly tagged as person(CPL) :+1:
Edit 2: The photo of the zone detection is now loading correctly but still no landscape view since a long time. I don’t know if the landscape adjustment has been abandoned…
@WyzeBaohua
I updated several of my (non-critical, learned my lesson) v2’s. Like @gyzmo using a playback record still yields a “corrupted” recording and a black preview. Video recordings work fine if I take it off the SD card directly.
Luckily, this beta (SO FAR) hasn’t suffered from the previous “forget configuration” bug where the camera won’t remember wifi settings on restart/power-off.
Updated just fine on my V2 cam without any issues and I’ve not experienced any corrupted video playback like a few have reported above but I will keep an eye out for it.
Need to charge my V2 outdoor and test.
Updated both versions of WCO and v2 cam, no issues!
Edit:
Oop, turns out it’s cuz the update failed… on all of them… trying again, could be my internet being dead
12 V2 and two Pans updated without incident.
Thank you for the feedback. After investigating the playback recording issue, it is not related to the new firmware but a 2.34 iOS app bug. We will work on the app to fix it.
I’m happy to report that I’ve updated 10 of my v2’s and Pans to this firmware beta, from the problematic 1273 beta, all so far (24 hours in) have worked much better than 1273 beta, in that none have needed power unplugged/replugged (yet). Two of the 10 did not “take” the latest firmware update until after 2 or more attempts, but all 10 are now updated. With 1273 beta, 3 of the 10 would not stay operational more than a few hours before needing to be unplugged/replugged. Thanks Wyze for getting me past 1273, I’m once again a happy beta-tester.
Update:
Initiated an update last night for all cams after the failure, then went to bed. In the morning, all were updated and working except the v2 cam. That took another attempt then it worked.
Ok so I have not gotten any update on my Outdoor v2 cam. I noticed I was on a very old update and it wasn’t even listed on the site. It’s just never updated, so I manually flashed the latest one I can see which is 4.48.4.124 which worked but I still can not see this latest update, is there a possible reason why? I’m going to try repairing the device and see what happens and will update.
No luck with the repairing and double checked I’m set to be in the Beta but still not seeing the firmware update.
I am still seeing choppiness / dropped frames on my Pan V1s with CP detections (e.g., Person detected) as with the previous beta, although possibly to a lesser extent. The constant upload activity has stopped with this beta, which I am very thankful for.
@WyzeBaohua
One of my v2’s had a problem after the update process. It flashed properly but then experienced the “won’t remember wifi settings on restart/power-off” issue. Attempted to reestablish the parameters and camera did work for that duration, but when I powered it down to move it back to its mounting spot, it failed to remember wifi configurations. Reverted back to 4.9.8.1002 and working normally now. Hopefully the ones that did upgrade properly won’t exhibit this issue.
I’m still not seeing this update on my outdoor V2.
Updated Cam v2 to 4.9.9.1355 and suddenly rules (in conjunction with remote sensors) don’t work. I’ve clear cache, created new rules, reinstalled app, rebooted cam and sensor bridge - no dice.
When do we expect this firmware update to be released?
If you’re talking about 4.9.9.1355, should already be available as I can see the BETA offering in my update list - if you’re asking about the stable version of this, I’ll have to defer that to the Wyze folks.
