I have tried to upgrade 4 Wyze cams v2 and 2 Wyze cams pan to this new firmware and they are all offline. The cameras keep trying to reconnect - they have a flashing blue light so are connecting to the Wifi but are not going online.
Glad it’s working for some folks! For the others, if you unplug the camera and plug it in, does it help?
If not, could you please send in a log through Account > Help & Feedback and then post your log number here? I’ll tell the team!
I have just attempted to upgrade, both over the air and using sdcard, cam is now offline. After powering off and back on I have a flashing blue light on the back of cam. That is all…
all the updates cause all 3 of my cams to give me error code 90 and i cant fix it, i cant get any cams to connect
i did that, unplug, restart, add new and all my cams will not connect, it gives me an error 90 then when i delete and add it will not connect. Please fix the update. All cams are inop at this time
im in the same boat. Super frustrated and i really cant do the manual way either
All my cameras are now offline after the update. The only workaround is to downgrade it to 156. This worked for me. I urge anyone who got theirs offline to manually update to 156.
Download the old 156 firmware (July 2020) and install that manually. 191 Didn’t work for me (both auto and manual).
Download the old 156 firmware (July 2020) and install that manually. 191 Didn’t work for me (both auto and manual). Try this
Not such a great solution if a cam is in a difficult to reach location, or used by someone with no technical background. I suggest the upgrade is withdrawn, fixed and reissued.
The only thing that worked for me was to download 156 version. Could you please fix this for us? I reckon there’s a massive number of users affected by this 191 update. Keep us posted once 192 or whatever the next version comes out
I’m letting the team know about these reports. Most folks are out of the office now but I’ve sent a few messages in different areas.
Haha same boat mate. I had to manually reach all of my cams that are outside with a ladder ![]()
Stop advertising the update!
Same here. Immediately post update all cams are offline despite power cycling. Update appears to be bad! Don’t install!!!
Thank goodness I checked this fine forum. Rather than update…I’m going to have a beer ![]()
Just installed a Reolink E1 today. Works as advertised, many more functional options than Wyze, PC and/or Apple app with full control of the camera. Better than Wyze in every respect except footprint. I think I’ve found my Wyze replacements. ![]()
I upgraded three cameras and they are all offline. I unplugged them all and replugged in but problem persists. Hopefully, it is recording at least. Help!
We have this update paused as we look into what is causing this problem for some folks. If you are having trouble with your Wyze Cam being offline after the firmware update, please send in a log.
The usual method won’t work because the camera is offline. This time, please generate a log by putting a microSD card into your Wyze Cam, waiting for the ding ding sound, and then read the file with a computer. When you find the most recent one (they’re named with dates), please make sure it was generated around the time you tried to get a long and, if so, send it in an email to xli@wyze.com. If not, you can insert the microSD card again if you want to try again.
I am having the same problem as everyone else.
You are supposed to be reliable, You are the first security cam company i have ever went with and i am paying for your services monthly. are the other company’s more reliable?
