Wyze cam OG Telephoto Firmware
Will not update firmware
Why ?
Let’s start off with what version do you have on your OG-Tele?
And are you a beta tester for that camera type?
Not a beta tester
see attached for bersion
Have you tried clicking on Firmware Version in your above screenshot and are you not given the option of manually starting the update process?
Yes i have
update failed
tried numerous times
The camera is new, yet firmware version in it now seems to be several versions old
One thing to try is move the camera very close to your WiFi router just to try to update (even if it seems to be close enough).
Worth a try and then move it back if you want.
Thanks, but it only about 6ft away
i will put it right on top of it and try
You don’t want to put it right on top of your wifi, there is such a thing as too close. 6 feet should be fine. Reboot the camera and try the update again.
It is possible that for some reason your router or ISP is blocking connectivity to the Wyze server that downloads the firmware. Unlikely, but possible. Are you using an ISP provided router, and/or does your router have any sort of “advanced security” or “strict firewall” or anything like that?
While you are rebooting your camera, also restart your cable modem and WiFi router / access point too.
That did not help
I order a new unit from AMZ
Hopefully it will work
I have 6 wyze V4 cams on the same router and I was able to update them
I will look at router settings
Have you tried a factory reset?
https://support.wyze.com/hc/en-us/articles/12017725675803-How-to-factory-reset-your-Wyze-Cam-OG
I turned off all router protection
did not help
Won’t start the update or update failing?
I believe the update is Failing from the screenshot above.
Update fails
I got this message, too, when I updated a floodlight pro. A retry worked.
Edit -
Which is actually good news. It’s because it implies that now the firmware update process first downloads the whole file before installing the update. Wyze is listening to my rants.
With Error Code 13 might be related to bandwidth. You might make sure nobody on your network is downloading lots of data while you are trying to update.
We have fiber service here
500mb service
i have tried it 20+ times over many days
I turned off the router security setting but did not help
I updated other cameras no problem
i ordered a new camera from AMZ
Should be here soon
