Wyze Cam OG - Released 1/17/2023
I placed my order for two telephotos one going to a different place one going to me on 18th
one says paid partial the other one says paid unfulfilled
I read through this :thread: and thought that maybe it would be a good time and place to share some feedback on the OG…
1 - The setup experience of Cam OG was SUPER fast, and simple compared to every other Wyze Cam or Device! And I have over 20 cams myself across all versions.
2 - Notifications really are very fast and loading the live view is much faster than my other cameras (all on the same network).
3 - The OG mount plate/bracket was slightly confusing in how to remove it from the base. The Quick Start Guide seems to assume camera, base/stand, and mounting bracket come UNassembled.
It took me a few tries, being gentle enough not to break my new gadget and firm enough to know the plate needs to SLIDE in one direction and not pull or twist etc.
I am impressed with it once again like back when I got the first v3. Great quality and features for a really great price. And I am excited to try it with the OG Telephoto when that arrives :wink:
Nice! I wonder how long the OG will stay at the $19.95 price. Thanks for the review!!
Waiting for when these 3X or more telephoto zoom capability iteration’s are incorporated into the pan/tilt models that recently debuted
Yeah, I have got the Standard OG’s from my order, just no Telephoto :frowning:
Thanks for the response, at least I know I’m not alone.
When is OG Tele shipping? Can someone from Wyze comment?
Regards,
sv11
@sv11
I will check tomorrow to see if I can get a better idea but I believe it was shipping 3-5 days after the Wyze OG. I could be wrong though and will look into this tomorrow.
I just unpacked my new OG… It’s not listed under “add device”
Check the Wyze app version on your iOS/Android device. You probably just need an update.
Thanks… that worked!
Its been 6 days for me, and no response from Wyze when I ask about it. I’m pretty disappointed on the lack of communication and transparency.
Well I purchased 3 of the OG cameras, however, I believe the only reason for launching the OG cameras was to move people from cam plus lite.
Other than the price, the V3 is pretty close,minus a spotlight.
Reason for the cheap camera price…they make more money off subscription services.
On the OG Telephoto, since this isn’t a pan camera, are you able to electronically pan the camera around? The write-up says something like “The wide-angle OG views the entire area and the OGT lets you zoom in on the details.” That sort of implies that the entire field of view of the OG is available to zoom in on with the OGT, which means it would have to be able to pan around that entire field.
The OG cameras work just like the other fixed cameras such as the V3. You can digitally zoom into the image using the finger pinch gesture. Bear in mind that you are not gaining any actual resolution. Once digitally zoomed in, you can pan the image by dragging with one finger to show any area of the original zoomed-out image.
With the OG/T, it works the same, the difference being that you are starting at a point 3X closer than the OG/S.
FTYI, just received shipped notice for my two OG Tele cameras.
Same here
Got it — Thanks.
The mount hole is metric, M4 (4 mm) diameter with 0.7 mm thread pitch. There are adapters on amazon as others have pointed out.
Like this :
Thanks a lot :grinning:!
It will be much much better if Wyze had kept the 1/4" mount hole used by all previous cams with mounting holes and increasing price by perhaps less than $1.00 ! Just sticking to OG $20.00 price target should not be a hard target since the price is affected by tariffs, exchange rates etc … Keeping customers happy by keeping good standards/practices and improving not so good ones are much more more crucial!
Received my two OG Tele cameras today. Funny, the track your package on the shipping notice shows that it is still waiting for carrier pickup.
The zoom picture looks good. I’m going to put it right besides another camera (V3 most likely) so I can compare them side by side.
