Hello everyone,
I’m hoping to get some insight into a bizarre and incredibly frustrating issue I’m having with my Wyze Cam Floodlight Pro. The camera is hardwired with constant power, but it has fallen into a state where the Wyze app continuously shows a “This device is offline” overlay with a frozen thumbnail.
Here is the catch: The hardware and local AI are 100% alive.
When I walk into the driveway, the camera physically tracks me, triggers the floodlight, and plays the local voice recording warning “You are being recorded.” It is executing its local automation perfectly, but it is experiencing a complete one-way cloud communication block and refuses to stream live video to the app.
My Setup:
Camera: Wyze Cam Floodlight Pro (hardwired directly into a garage ceiling junction box by an electrician, receiving constant power).
Network: TP-Link Deco Mesh system. I recently purchased and installed a brand-new Deco unit directly in the garage specifically to give this camera a pristine signal.
What I Have Already Done to Troubleshoot:
We have completely optimized the network side to the absolute limit, eliminating every standard Wi-Fi bottleneck, without success:
1. IP Address Reservation: Assigned a static DHCP IP reservation (192.168.68.76) inside the Deco app so the router never dynamically changes its slot.
2. Node Locking: Locked the camera strictly to the new Garage Deco node. The app explicitly states “This client will ONLY connect to Garage Deco.”
3. Wi-Fi Band Isolation: We tried locking the preferred band strictly to 2.4 GHz to eliminate band-steering confusion. We also tested switching it to 5 GHz to utilize the Pro’s dual-band capability for its high-res 2.5K data stream. Neither changed the offline status.
4. Disabled Advanced Router Features: Disabled both Fast Roaming and Beamforming globally/locally in the Deco settings to prevent dynamic packet shaping from dropping the camera’s wireless module.
5. Custom DNS: Changed the router’s WAN DNS from Auto to Manual, routing through Google’s public DNS (8.8.8.8 / 8.8.4.4) to bypass any ISP cloud handshake issues.
6. App & Phone Reset: Force-closed the Wyze app, cleared app caches, and cycled phone Wi-Fi connections.
The Core Problem:
Despite a flawless, dedicated Wi-Fi signal inches away from the garage node, the camera’s wireless module seems completely locked up regarding cloud sync. Because the electrician hardwired it directly to the garage circuit for constant power, I have no physical power switch to easily reboot the unit when it gets into this frozen state—forcing me to trip the main house breaker just to power cycle it.
Before I pay an electrician to come back out to install a physical inline toggle switch to force-reboot it, or change out the camera for a different one, has anyone seen the Floodlight Pro’s network module completely freeze up like this while the local AI/motion hardware continues to run perfectly fine? Is this a known firmware handshake glitch with mesh networks, or am I looking at a hardware defect in the camera’s wireless transmitter?
Any help or insight from the community or Wyze team would be greatly appreciated!
