I’ve read a couple threads about a similar but not exactly the same situation as mine and did those troubleshooting processes and none worked out so far.
I have a 2020 Wyze Bulb that I originally used in my garage that automatically turns on when a motion is detected by a Wyze Motion Sensor then turns off after 20 mins.
I’ve recently moved the bulb inside the house and renamed it. I turned it on manually but it turned off by itself. I then remembered that I have a rule in place between the sensor and the light so I went to try and delete that.
However, and this is where it gets confusing, I don’t see the motion sensor in my app. I either deleted it in the past and forgot about it or it’s just not showing (I’m assuming it would be the first). I first checked the rule to delete it but I don’t see it in my rules page. So I moved on from that and tried to do a factory reset on the bulb since Wyze said that doing so basically makes it a fresh device and it gets disassociated with any rule or schedule. I successfully added it but it’s still following the original rule (which is to turn the bulb on for 10 minutes then turns off). I’ve since done 3 factory resets with it and still nothing.
Would anyone know how I can really wipe it clean so I can re-use it?
Update: I now remember why I don’t have the motion sensor. I later added a garage door and camera in my garage so I just used that as my "sound” and “motion detector.” So I went to see if there was a dedicated rules page for that device but turns out, all the rules are in the rules page already so I’m back to square one.
