Wyze app 3.3.5 - Released 2/20/2025
It’s not. I see it on Android if I select the  Account tab. I just don’t let it bother me. :man_shrugging:
From Jasper in above post:
there’s no way to remove it unless you subscribe to the Cam Unlimited Pro service
… which seems to imply that it can only be removed if one has the pro
Right, that seems accurate about getting rid of the dot, but I wasn’t asking about that. I quoted your previous statement:
I don’t know what “ultimate” is and haven’t seen that described anywhere, so I was requesting more information about that.
Cam Plus Ultimate, all-you-can-eat plan
I’m still not seeing that on the plan comparison page or anywhere else. The highest available tier I’m seeing is Cam Unlimited Pro. :confounded:
Looks like I’m using the old name.
That looks like the mid-tier Cam Unlimited service, unless I’m missing something. I’m just trying to figure out what “ultimate” is, but I’ve long been confused by Wyze’s service naming scheme. :man_shrugging:
Cam Unlimited is actually an overkill for me. I only need cloud recording for 6 cameras.
Funny. That was our assumption. Odd that non-subscribers are not red dotted.
Same issue has been happening to me. Started about 2 weeks ago. Restarted, reset, unplugged, rebooted model and router, checked network settings, security etc and checked the same settings as you. Started after the last update and it’s extremely annoying. I hope they understand that this appears to be the update/software issue and get to work on this fast.
I’d rather roll it back until they get something fixed or figure it out.
Keeps this thread going for updates. Thanks and if anything changes on my end, I’ll advise.
Android only user/PC/EMULATION software on the PC like yourself.
Late
All 14 of my V3s have the error. Luckily, they aren’t my main cams anymore. I still hv views, but not like I need to be comfy.
I like my WYZE, but they don’t have the reliability to be a security cameras. They need to slooooow down production and creation new products, and get the Flagship cams on point imo.
I’ll get back when/if anything changes.
Cheers
Same here, still an ongoing issue, that only started since the most recent app update.
— I have tried EVERTYTHING. Evem trying to tune the network adapter settings, also reset storage & cache, there is NO reason the error should be happening now, I also get the error with my Motorola smart phone but not as much, as the emulator…since the lastest update. I also would consider rolling back to the previous App build but I looked for it, and can’t find it as a download.
So we seem to be stuck in this situation, and I am not too happy, as I use teh app on the Emulator/Desktop, a LOT more, than the app being on my smartphone. My network is Gigabit, and my internet connection is Verizon FIOS Gigabit, so there is no reason this should be happening after the latest app release.
I even tried loweing the Cam resolution so there is less bandwidth used, but it is still an issue.
The last App build it was not an issue.
Arggg
Pick the one you want to download and install with APKMirror Installer app.
I tried to install the APKMirror app, and my firewall raises a red flag, regarding security and the site SSL certificate… I backed out.
I appreciate the information and link though.
The other though it I am always going to have to keep checking that Google Auto Update doesn’t turn itself back on, as I have seen this happen many times.
Wyze could easily offer the process to roll back an app build/version release.
