iOS app 3.2.0 just installed and you broke streaming music yet again. It cuts off when I drill down into a camera regardless of the sound setting but it at least used to resume music after I backed out of single camera view. Can you please fix it again? Thx
Yep, available for me as well. ![]()
This feature is nice.
It sure loads faster now. ![]()
I think so too. The streaming camera views seem to pop right up.
Autoplay toggle appears to be maintained at the account-level vs device-level. I found a problem where when 1st device has autoplay toggled off and works fine, load 3.2 on 2nd device and autoplay is enabled coming into Favorites, but upon checking autoplay toggle, it was off. Went back to Favorites and cams autoplayed. Went back to toggle, toggled on, toggled off, went back to Favorites, still autoplaying. Killed app, restarted, autoplay off as expected. I’ll play with this multi-device stuff sometime later. Taking on too much multitasking right now. ![]()
Sure wish they would list the fixes, especially ones that impact features. They’ve been"working" an automation issue for weeks now. Would be nice to know if it’s been addressed
I agree. Detail all feature changes.
In this case, the card change and update to auto-streaming is something to really hype. It’s cool. Toggles are great for whichever view you want.
This app has made very significant progress since 3.0 first release. I couldn’t even imagine going back to 2.5. This version is pretty slick looking with the compact view.
Now… onto version 3.3… Project Goals. Landscape view across all devices and DARK MODE XXXX!!!
my eyes … my eyes…
I loaded the V3Pro firmware on 5 cameras. All 5 upload cloud events. Only 4 will Livestream and 1 will not. I’ve tried restarting it a few times with no change. Will have to try clearing the cache and restarting the phone later. At least it does events and notifications though
I agree that a bulleted list of bug fixes would be nice.
What automation issues are you experiencing?
A bug from Wyze Android beta app v3.1.0.b560 which @smellslikeMI and @K6CCC reported still exists in this latest beta app.
Whenever I try to record a clip on my Cam V3, it only saves an PNG image of when it stopped recording. The video clip is no where to be seen. Only when I force close the Gallery app and open it again does it finally show the video clip.
Below is the list of Android app version which exhibit this issue.
v3.2.0.b574 issue
v3.1.5.569 issue
v3.1.0.564 issue
v3.0.5.558 okay
v3.0.0.519 okay
v2.50.9.512 okay
Cam V3 FW: 4.36.13.0416
Wyze Android app: v3.2.0.b574
Samsung Gallery app v14.5.01.2
Samsung Galaxy S20 FE on One UI 5.1 (Android 13)
Been running 3.2 for about 12 hours now. As @Earl.Automation said
The Favorites now allows best of both worlds. You can have a 2.5 look with cameras listed with thumbnails and a camera group that live streams all cameras in the group.
This is a huge improvement over the 569, and previous releases.
To all beta testers of this release. Wyze needs to get this into a production release as soon as possible. Anything we can do to expedite this I’m sure would be appreciated at Wyze👍
p. s my 3 Pan Scan v3’s and 1 v3pro updated successfully and seem stable with no issues.
3.2.0 b574
Android 14
Samsung S21 Ultra
Issue with Notifications.
I was reading thread
I said to self - - have I seen this issue? If so it had never been an issue. The way my cameras are set up is 5 outside cameras with notifications turned on and 5 indoor cameras with notifications turned off. I get a few notifications a day as the dog goes in and out, package being delivered, family in and out. Very manageable.
I decided to turn on the most used room in the house, a Pan Scan V3 in the living room. When I went to events I saw the expected red bar that said notifications are turned off–enable? I click on it and it does not clear. I clicked a few more times and it did not clear. Then went to Notifications. It showed off. I tried to turn it on and it just blinked at me and stayed off.
As the Pan Scan v3 had just been updated I said ahah. Must be the update. I then checked my other 3 Pan Scans and my v3 pro. Same. Cannot change Notifications.
Then for grins checked my other cams. A v4, Doorbell v2 also showed this symptom and they were not involved in the recent Pan Scan, v3pro update. Of interest my old V3, OG, OG-T do not seem to have this issue.
I have done the usual. Cleared cache restarted app, logged out and in, camera restart and reset. No change.
I think this issue is due to the 3.2.0 b574 update.
I do not have a work around. As time permits I may try reinstalling a camera.
I’m glad someone else is commenting on this. I’m not a β tester or iOS user, but on Android when I’m listening to podcasts via Bluetooth speaker or Wyze Headphones and open the Wyze app (v3.0.5.558 production) to view a camera’s Live Stream, the camera’s audio interrupts the podcast audio—which is absolutely fine, especially if the camera I’m looking at is a doorbell; this is the behavior I would expect—while the Live Stream is displayed but then doesn’t return the audio to the previous settings, and I usually have to reboot my phone to resolve that.
It’s not a hugely crucial issue, but it’s definitely annoying when I just want to resume my prior listening.
Great find! I didn’t see this. I noticed that the condensed view isn’t actually a live view, but thumbnails. I would LOVE if these were live! Maybe a toggle for making the condensed view live?
Otherwise, this app feels MUCH more mature now. Positive steps in the right direction. Loving the quick swiping between events, as well as the re-designed UI. It feels much more premium, and well thought out. Oh, and the favorites are loading SO much faster…almost immediately!
No bugs so far…
I doubt that is possible, you can’t have the cake and eat it all ![]()
The reason why the app feels faster is just because the thumbnails are static. You add video to them and it will be the same crap show as it was before. Let it be my friend.
They meant apply the autoplay option to thumbnails so it’s not forced.
