Wyze app 2.43 Release Candidate & Cam Pan v3 Firmware Beta Test 6/26/2023
Yes the fix did not make it into this beta version but it should make it to the public version, we are still finalizing the fix for this.
This app version should also fix the long-standing scale issue where it would not download data unless you weighed in with the app already open.
Thanks Jason - Appreciate the info
Thanks Jason. Appreciate the feedback
After seing an event, you return at the top of the list instead the event you were. (IOS)
Tested this on my #$%^&* iPhone 13. Sometimes after watching an event, it went back to the top of the list and sometimes is stayed at the event you had just watched. MIGHT be camera type, but not sure about that one - not enough samples tested. V2 and V3 Pro seemed to go back to the top of the list and V3 and OG-Tele returned to the list where it had been.
Short test on android always goes back to the list where it had been before.
The majority of time, it goes back to the top but occasionally, stay at where you were(V2, v3, pansV1, iPhone13).
Edit: reinstalled 2.43.0(5) and the issue is not there. Always go back where you were.
Can’t speak for others’ experience, but as I reported this morning (see above), the latest Beta app, 2.43.0 (9) I presume, has resolved the audio cutoff issue on my 2021 (5th gen) iPad Pro 11" w/ iPadOS 16.5.1. Just tested again by … 1) launching MLB.tv app on my iPad and playing the radio broadcast of a game from yesterday, then 2) closed MLB.tv app, then 3) launched the WyzeBeta app 2.43.0 (9) and the play-by-play of the baseball game kept playing. Could have tested with Pandora, SiriusXM, Apple Music, etc. and likely had the same result. @WyzeJasonJ @carverofchoice @Slammer99uk @gyzmo
This is a celebratory/kudos comment… I am THRILLED to see system PiP on iOS for the FLP!!! Well freaking done!
@WyzeJasonJ
The camera “On/Off” icons are not lining up and are shifting in real time.
Log ID: 1093850
iPhone 12 Pro Max
Camera’s in groups aren’t loading unless tapped into. Then once exiting to the multi camera view it loses the stream again.
Log ID: 1093906
iPhone 12 Pro Max
iOS 17 Dev Beta #2
“Playback” button from events tab error…“MicroSD Card Not Found”
My installed SD cards are recording successfully, I can see the recordings from Home tab, select camera, “SD Card” button.
Log id 1094002
@cyberdog_17 , Just tested PIP as well. Seems to only works on iOS for the Flood Light Pro when in Landscape mode. Does not work on Android at all or any other camera at this time.
Hoping it will work in Landscape or Portrait mode for all cameras on both platforms.
But it is a great addition, really liking it.
Just wondering… are you running the Android 2.43.0.b309 beta app and/or Cam Pan v3 beta 4.50.4.4767 firmware?
I noticed your screenshot was taken a week prior to the beta app and beta firmware availability (phone system date, file date and screenshot date).
Theres no 2.43 app in My apple store. why?
I don’t have this issue since 2.43.0(5) on my side.
I love that someone figured out how to use the Picture in Picture (on iOS).
I see that the Android App settings also allow for Picture-in-Picture now, but it’s just not been added into the Android app yet:
Hopefully the devs can get this added into android by the public launch or if not, maybe at least in the next App version.
Yep,I’m running the new beta 2.43.0.b309.
I did use a screenshot from the most stable version because it was on hand, but I’m getting the same error on both beta and stable.
“Someone” hmmmmm I wonder
I already gave you a gold star for it privately. What more do you want? I can’t let this go to your head too much. :slight_smile: Besides, what I meant was that it doesn’t really matter who figured it out, just that we know it works. :slight_smile: I’d be happy no matter who figured it out…that’s what I mean by “someone.” :wink:
