The Recent Events preview is too small. Even on an iPad. Before, you could get an idea of what the event was, from the preview. Now…not at all.
On iOS, you don’t have to scroll the way up to get to the select all/cancel button after clicking on the pencil. This is an Android bug and I reported it via Customer Support. I suggest you report it as well.
It’s not a bug it was programmed that way. So, a mistake.
I reported it during the beta.
Still works in Android, but…
Separately… the bolded below no existum in Android:
I’m talking about the cancel/select all option scrolling off after you hit the pencil…@newshound confirmed it does not scroll off on iOS . It scrolls off on Android. Therefore, I believe that’s an Android bug.
The calendar and edit menu scrolling off before you hit the pencil icon is probably a design change that made it inconvenient. Yeah I do remember reading that you reported this issue.
They are the same problem.
That area of the screen should be static at all times no matter which menu is showing, calendar or edit.
Yeah I agree, but at least on iOS the select all/cancel is static after clicking the pencil icon. It should be consistent on both platforms.
Yes it should be but the two platforms don’'t share code so it probably just got overlooked, I hope.
Hopefully my reported issue doesn’t cause them to make the cancel/select all menu scroll off on iOS too haha.
Not half-cocked! Open the frizzen and prime that pan!
What I have noticed on at least two phones ( Android 6 and 9 ) in that when I swipe through events, the swiping works fine forwards & backwards, UNTIL I try to swipe backward over an hour boundary.
Then I get what you see below. A “Loading” screen followed shortly by the “clip doesn’t exist” screen.
But it always says “Motion at 7:00 PM” no matter what hour boundary I am trying to cross.
And there is no missing clip - I can load & view every one in the events list, I just cannot swipe across hour boundaries.
Not a fatal flaw, but definitely something weird going on…
I am not experiencing this on iOS.
Yeah I was able to replicate what you just posted as well on Android 10. Please report this issue when you have time. That’s very odd. Mine shows up motion at 6:00 p.m. when I try to swipe events past the hour mark. I’ll report it as well.
I get the same on Android 9. Motion at 8:00 PM. Different time zones maybe?
Good eye, sod man!
Thanks! We’ll see what happens!
I reported it to Wyze as @cheaplikeafox suggested and JonathanP of Wyze replied very quickly to say they had engineers working on it and hoped to fix the issue in a future release. He also requested log files, so I sent them in from the two devices. As computer updaters the world over say… “and now we wait…”
Good theory @angus.black - I’m currently on EDT. The Wyze app does sometimes seem funny about time. Running it inside MEmu with the “fake location” feature turned on really messes with it.
I hope to be taller and more handsome by then. Taller, handsomer, swiping smoothly through events. :shudder: I think I just “arrived.”
I am in the Atlantic time zone, 1 hour later that you.
So if @cheaplikeafox is on Central time, then the theory holds, and, ignoring daylight time, we would each be getting a time equal to midnight GMT. Which seems like something a computer program would do…
A lot of people on iOS have been having issues loading the camera live-streams.
No longer works on my iPad. After selecting the Events tab and viewing one of the saved 12-second clips, I must now return to the list of events in order to select the next/previous one, versus just swiping forward/backward while viewing. Any other iOS/iPadOS users out there experiencing this?
On two older iPhones ( iOS 10.3.3 and iOS 12.4.6 ) I just discovered that I cannot swipe between days. So I cannot swipe from the first/last event of one day to the last/first event of an adjoining day. But I can swipe between hours and events on the same day just fine.
