Wired Doorbell Chime Sensor fried?
We had previously installed the Doorbell Cam v2 (wired) to the front door and it worked great!
We realized our deck had a backdoor doorbell so we wanted to add another camera.
After we installed that they both worked fine for a few minutes and then they both died.
I assumed now that there were two, they weren’t getting enough power.
We then replaced the Doorbell Transformer to one that was 24V-20VA.
After doing that, one of the chime control dongles started making a rapid clicking noise and started smelling like burning plastic. So we cut the power and switched back to 16V-10VA. after turning the power back on it was still clicking.
So we’ve cut power to the doorbell and haven’t tried again. We’re planning on consulting an electrician about the transformer, but I assume the doorbell chime itself may be toast.
Has anyone experienced this before? Any tips? Can we get a replacement chime controller?
Welcome to the Forum, @joe.lutovsky! :wave:
I haven’t experienced this, no. I get the sense that you diagnosed the problem with the Chime Controller and learned why Wyze says to use it even if your chime is broken:
the fuse wire in the included chime controller protects your new doorbell from high voltage that may cause damage.
I think consulting an electrician in this case is a good idea. If you feel comfortable doing your own work and have the ability to test your circuits and measure voltages, then it’s possible that you could wire in your own relay, as other users apparently have:
I’m not sure from your initial post if you have two separate doorbell buttons and chime boxes or two doorbell buttons activating chimes in a single box, so I still think I might lean toward the electician.
I don’t think this is possible, but you could contact Wyze Customer Support and find out. If Wyze is going to refer to a “fuse wire” as part of the Chime Controller assembly, though, then it makes sense that this might be a consumable part that would need individual replacement at some point. It seems like it should be possible to buy one separately from Wyze.
If/when you get this resolved, I hope you’ll take the time to give us an update. I’m curious about how this is going to turn out for you.
For whatever it’s worth, responding in another topic reminded me of your question:
Apparently they’re available only via the app (not the Web site) at present.
I hope you were able to find a solution to your issue!
@joe.lutovsky - Single transformer for 2 chimes in separate locations? Controller at each chime would appear to be a necessity. Would upgrade transformer to 16/30 or better still 24/40. Post outcome should you make changes that work. Controller is $13.99 in the Shop on the Wyze phone app.
