I recently bought a Wyze Cam V3 Pro to replace one of my V3 which is located outdoor under the eave.
First of all, I did the setup inside the house with the power supply 5V 2A included with the Cam, Once done and working as expected, I replaced the V3 by the V3 Pro and it started blinking red/blue non-stop. So I looked at the voltage at the camera and was reading 4.36V and 0.32A.
Note: I wanted my cam to be power by UPS so I did it like that:
UPS → 5V/2A Wyze Power Supply → USB to Ethernet adapter → Cat5e 25ft cable → Ethernet to USB adapter → 20ft USB cable → Wyze Cam V3 Pro
So I returned inside the house and tested voltage right after the power supply:
So it’s only outdoor were the cam refuse to connect to Wifi while the V3 works just fine. I am using Plume Superpods as Mesh Wifi at home and did not have any issues with other Wyze Cam V2 or V3 so far. So the question is: do you think voltage it too low outside to make the V3 Pro works? Or is it just a Wifi issue?
Most of those flaming people exposed the indoor-only adapters to outdoor moisture.
Running higher than 5 volts to the adapters and converting it there in a waterproof solution is a good way to go. Even if you run 120V most of the way – but not outdoors without protection!
Another trick is to measure the outputs of your adapters under load, and pick the one that puts out the most voltage. I recently found out the Wasserstein WOC adapters are actually tuned higher for voltage, pre-anticipating the voltage drop of their 25-ft cable. So if you have one of those, give it a look.
